Replacing license plate lights
Yes there is a spring clip, but you can't remove the light without removing the 3 or 4 the T25 TORX hidden under square plastic covers to remove the whole set-up including the trunk release button. Once you remove the T25, you can remove the lights depressing the spring and pushing them toward the "ground".
JacksonvilleJag (09-18-2020)
It's really easy, just use a small screw driver to remove the square covers, there is a tab on one side and then one on the opposite side, then just remove the TORX screws and it comes off.
