Restricted Performance Saga
Hello everyone, this is a continuation of my prolonged battle trying to fix my F-Type's "Restricted Performance" issue. Today marks 6 months since it first occurred and every day I get closer to losing my mind.
The short version is that my throttle is only getting 2.5V when it should be getting 5V. There is more detail in my previous two threads here: Initial Post, Followup Post.
Things we have replaced to try and fix it:
I'm losing my mind here guys. Any thoughts, wisdom, guidance, prayers would be very much appreciated. Thank you.
- Throttle Body
- Accelerator Pedal
- ECM (twice)
- BCM
- Battery
- Boost Sensor
- Low Fuel Sensor
Unfortunately, I think there are too few JLR dealers whose service technicians have much experience with F-Types.
So, not only are remaining dealers few and far apart but when you get there they have inadequate knowledge to get the job done.
I guess it is consequence of owning a relatively uncommon vehicle, and it is only going to get worse.
Sadly this is the second dealership I've been to. The other one in town didn't even touch my car for 2 months. The next closest dealership is an hour away..
Should have mentioned this but we did open a "technical case" with Jaguar where they did diagnostics with the technicians in the UK. They do seem to be doing a bit of diagnosing but I also have to agree they still have no idea and are just throwing parts at it..
I just got the car back from my indy mechanic after getting a couple new injectors and he casually said "hey, you have a code for the humidity sensor for the AC." He then gave me the part number so I can order it and put it in myself. It's almost like he respects me and wants to help me out.
I have had the same problem! And it's a good one to have. It is wild how much easier it is to spend money when the person you are giving it to seems to care and listens and makes suggestions and is helpful.
There is a reason the call them service technician's and not mechanics, they read a book and go to a class or two. Unless you get someone who can do a traceback, you will be at the dealerships mercy, you need someone to trace the wiring back till they get the correct voltage or if it is a ground issue, find the bad ground. Not sure what to tell you here, as I had a friend with an XKR and it would have the wipers turn off and on at various times, along with the radio turning off and on. Took a MECHANIC two months to trace it to a rusted ground on the frame.
Will not go into the issues I have with mine and the dealership experience.
burmaz
11-23-2010 03:39 AM
