Retrofit OEM rear parking Camera
My coupe severely lacks visibility out the back and I would love to add in the rear parking camera. I know there are several aftermarket options such as NAV TV, but I would like to explore the possibility of retrofitting the OEM system. I have seen several posts, with lots of feedback that it can’t be done, especially by dealers. However, I am sure it can, it’s just understanding what needs to be done.
From the short investigation I have done you clearly need a camera and a hole in your bumper, plus a new rear bumper wiring loom. To enable the camera you need to change the CCF. Do you need to do more than this ?
One more thing, my car is MY16 and I know the camera changed this year, so its making sure you get the right camera.
DISREGARD the below, I forgot it uses the ODB port.
If you use your mobile phone for media/Nav as most of us do, there is a license plate cam solution for about $400. The electronics in the F-type aren't great, so many look for workarounds. Maybe the 2018 models are better in some ways, but surely lacking vs even Japanese economy cars.
It is possible to retrofit the factory camera on the F-Types with the IAM2.1 infotainment, I haven't tried this on a newer car with the NGI/NLI infotainment though.
Yes it would need a CCF change to enable the camera, and the dealers are not permitted to make this change (actually their diagnostic tools are locked out from this functionality).
Not sure where you are in the UK but there are a couple of people there who I know are able to make these CCF changes.
You can actually buy the required cable as a spare part from Jaguar, well you used to be able to, I haven't checked this recently.
I have seen a few wiring looms available on ebay either as part of a wrecked bumper or separately. The cameras I am assuming will be the same ones fitted to most jags & LR's so can probably get one of these on ebay as well without having to pay 300-400 for a new one.
It just a case of the CCF and whether anything else is needed. I have the part numbers, Ill post those later.
Its not just the coupes. The vert with the top up has zero rear quarter views. Backing out of a spot with cars on either side requires literally "blind faith."
I have been interested in retro-fitting a rear camera since I got the car, and figured Nav Tv was the way to go since the dealer can and will install it without much drama. Doesn't solve the side view issue, but will help in other circumstances.
Paul - Following your thread with interest. There is a shop in the UK called Cartronics who have done this before, so we know it is possible. I think it was on a convertible. I asked if I could buy the complete kit of OEM parts from them and they said yes - priced it around 850 GBP.
Your harness part T2R14437 shows up on a few Jag part sites showing it is for cars without backup sensors, but that is probably an error (how many cars were built by Jaguar with a rear cam but no backup sensor? Probably none). According to my dealership parts department, this retrofit isn’t possible because the entire “body harness” would need changing and not just a bumper harness. I don’t know for sure but I’m used to cars having a common harness with connectors for the accessories.
Another concern is about the camera mounting. Drilling a hole is no problem but how does the OEM camera clip into the bumper, and will the flange around the lens cover the rough edge you will have after drilling?
Then we we need to find someone who will update the CCF.
the is a mount for the camera - part number T2R17785. There is also a suggestion that the buttons around the screen are different if you have a rear parking camera (cant think why this would be) T2R14074 w/camera vs T2R14076 without. I cant find anything other changes to any other part of the wiring loom.
Makes sense to me. Need the front parking sensor button that comes with the vision package (that includes the rear camera). Since you're not adding the sensors you might not need to change the buttons. (This assumes that those two features aren't added separately in the UK market).
It does indeed. I just wish it were not so, well, fisheyed. That wide angle grossly distorts depth perception. Gotta give up one thing to get another I suppose.
scm (09-19-2018)
NOTE: I actually rejected purchasing a '17 convertible because we learned late in the process that it did not have the vision package (so no rear view camera). When I was doing this same search, I was informed that the ENTIRE chassis cabling was needed but I never validated that detail as I decided to lease and was not going to make any modifications due to that fact. Good luck with the effort
Received 3,226 Likes
So does my 2015 R, it has been a very helpful feature. I would also get the blind spot monitoring again, I find that useful as well.
My car was in for a service on friday, The dealer had a F-type with the camera fitted. I checked out the dashboard and there is a difference. My car has a standby button in the bottom left position next to the touchscreen. In the car with the camera its the camera button !
So another one on the parts list !.
