Retrofitting LSD into V6
Old 01-13-2015, 09:50 AM
ParaPerf15's Avatar
Default Retrofitting LSD into V6
Hi all, this is my first post so hello.
I am wondering if it is possible and or has anybody fitted a limited slip diff from a V6 S into a V6.
I am aware that the v8 diff has a wiring loom and controls but a mechanical diff should fit straight in right?
Old 01-13-2015, 11:17 AM
duprey26's Avatar
I'll be interested to hear what others have to say on this, but here's what my dealer mechanic told me:
Jaguar USA will not allow their dealer mechanics to do it, but it should be doable by a third party mechanic. However, here's the deal breaker. The part is a $6000 (US) part at warrantee replacement cost; retail is likely even higher from Jaguar. If you could get the part number from Jaguar, you might be able to get it cheaper from the OEM, but it still sounds like it's a pretty pricy component.
I was interested, because it's probably the one thing I wanted most from the upgrade to the V6S. I'm more than happy with the power and other driving dynamics of the base car, but that is one item that I thought should be standard in a $70k RWD sports car.
Old 01-13-2015, 02:50 PM
Received 4,454 Likes on 2,426 Posts
From what I can see the complete diff with LSD centre is p/n T2R4000, has a retail price in the UK of £1323 plus tax, plus a £150 exchange surchage so about $2200 plus shipping/taxes/etc.
$6k seems a bit excessive....
Old 01-13-2015, 03:19 PM
duprey26's Avatar
Cambo, $2200 sounds more like what I was anticipating. As I said I was reporting what I got from my dealer mechanic as my first point of inquiry. Maybe he was confused, and was quoting the cost of the e-diff on the V-8. At any rate, I was not planning to do the swap anytime soon, since I'm fairly certain that JLR would use it as an excuse to void any warranty claim I might make on a power-train issue, so I took it no further.
For future reference, where did you get the part number from?
Old 01-13-2015, 03:35 PM
Unhingd (01-13-2015)
Old 01-13-2015, 03:58 PM
duprey26's Avatar
Originally Posted by Cambo351
OK, but how do you know that's the LSD for the F-type V6S? When I search for F-type parts, the site says they do not have them cataloged yet. Can't see any way from that site to be sure that's the correct part. Not doubting you, just curious how you know.
Old 01-13-2015, 03:59 PM
F-typical's Avatar
Hmm... So the regular differential (T2R4000E) is less than £1k? Or is that for a different car?
Old 01-13-2015, 04:11 PM
The E is for an exchange version i.e. rebuilt one.
Old 01-14-2015, 07:33 AM
duprey26's Avatar
Attachment 104502
Ah, so you have access to the secret decoder ring... How do us mere mortals get that? I'm fine with posting questions about part numbers on this forum if that's the answer. Anyway, thanks for the info on the LSD. When my warranty is up, I might seriously consider doing this, assuming I don't decide to upgrade to the V6S manual.
Old 01-14-2015, 01:32 PM
F-typical's Avatar
Attachment 104502
Sold!
Old 01-14-2015, 01:57 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Originally Posted by F-typical
Sold!
Comes with faster acceleration and lower fuel economy. (3.31 vs 3.15 final drive ratio)
Old 01-14-2015, 02:32 PM
tbird6's Avatar
I wonder if it fits any other Jaguar model?
That would be sweet if it did!
Old 01-14-2015, 06:54 PM
JgaXkr's Avatar
You will not be able to swap the diff as it will go into the limp mode because of incorrect gear ratio.
Old 01-14-2015, 07:20 PM
Unhingd's Avatar
Quite possibly, and other things like the cruise control might not work either. Since I threw a close ratio locking tranny in my MINI several years back, cruise control only works in 3rd gear (useless).
Old 01-14-2015, 09:36 PM
True but you would be able to swap the ring & pinion onto the new LSD center...
Old 01-15-2015, 07:41 AM
duprey26's Avatar
Curious why you think this is so? Do you think the computer system is that sophisticated to be constantly monitoring the ratio of transmission drive shaft RPM to rear axle RPM and faulting if it does not meet 3.15 within a tight enough tolerance that 3.31 is a fault condition? I'd be surprised if that's the case. Also struggling to understand how a LSD swap would affect cruise control. At the end of the day, they're both purely mechanical devices.
Old 01-15-2015, 09:08 AM
Unhingd's Avatar
I can't explain it either. The issue isn't with the LSD though, it's with the ratios. A number of those folks installing '05-'06 close ratio gear boxes in '02-'04 MINIs lost use of cruise control (except in 3rd gear), and it happened to about half of those who did the swap. That said, none of us had any issues with the car going into limp mode.
Old 01-15-2015, 03:32 PM
Have a read here https://www.jaguarforums.com/forum/g...ids-sdd-77299/ it's for the earlier model cars but the same would apply.
Basically changing the diff ratio without adjusting the software throws the car into limp mode.
This would not be the case with the manual transmission though...
Old 01-15-2015, 06:51 PM
JgaXkr's Avatar
I have to ask how do we know this to be true?
Old 01-15-2015, 07:03 PM
Which bit?
Quick Reply: Retrofitting LSD into V6
