Retrofitting LSD into V6
Old 10-10-2021, 12:02 PM
Dan Wink's Avatar
Originally Posted by airthirtytwo
Nope. Just about as straightforward as it could be.
I believe the exhaust needs to be dropped, but I wanted to confirm as I will tackle this (hopefully) tomorrow.
  #42
Old 08-04-2022, 08:08 PM
HermanWiegman's Avatar
I have a Manual Trans 2017 F-Type and I am looking to upgrade from an "open" rear diff to a Limited Slip version.
I hope to get the published part number of interest... so it easy to get a rear diff from the salvage yards.
(the Jaguar part number of interest T2R4000 is not printed on the part, so is not of use to salvage yards)
Here is what I have on Jaguar part numbers and the published part number
OEM Jaguar P/N
Base Model (Open Diff) ZF 8 Speed Auto T2R 17980 , Manual T2R 18657
S Model (Limited Slip) ZF 8 Speed Auto T2R 4000 , Manual T2P 1783
R Model (Electronic Diff) ZF 8 Speed Auto T2R22213 (replaces T2R15908)
Note: the label on the actual differential has a different part number that usually starts in EX53-#@###-@@
I have seen ratios of 3.15, 3.31, and 3.55
So just trying to zoom in on which tag number is the right one so I can order a Limited Slip Diff for my Manual F-Type
Thanks in advance for any more info.
Herminator
  #43
Old 10-19-2022, 10:33 PM
dbritt320's Avatar
Just did the LSD swap into a base automatic from a Type S donor. Can confirm it fits and drives without throwing any codes. I'm getting a slight howling noise at certain speed intervals which I am suspecting is due to the pre-load being out of spec. Definitely a noticeable difference and a lot of fun to get the wheels locked up on turns and cornering. Going to look into if any changes are needed to the ABS module as well.
Also in the process found out my car is loaded with VAP pulleys, downpipe, and lowering springs.
The following 2 users liked this post by dbritt320:
BONESTOCK (12-14-2022), Panthro (05-09-2024)
  #44
Old 12-14-2022, 05:59 PM
@dbritt320
Do you have a picture of the tag number from the rear differential Type S donor car?
It should be something like EX53-4A213-ZZ
How is the rear end working for you?
Do you drive with DCS in the "on" mode, or do you use TracDCS, or DCS off?
Inquiring minds want to know!
  #45
Old 12-14-2022, 07:04 PM
dbritt320's Avatar
Originally Posted by HermanWiegman
@dbritt320
I absolutely love it. No complaints at all. I drive with it both on and off... Definitely more fun with it off though .
  #46
Old 12-14-2022, 07:13 PM
BONESTOCK's Avatar
I'll be wanting to do this upgrade someday. So these rear ends...I can't just open up the diff like in my Mustang and swap the pumpkin out?
  #47
Old 12-14-2022, 07:26 PM
@BONESTOCK No.. Look in this thread on the latest info on the Ford 8.8 vs. Jag F-Type rear
https://www.jaguarforums.com/forum/f...-245971/page3/
@dbritt320 Interesting.. I have the -AA rear diff down as the early Automatic open diff.
Can you confirm it is an LSD?
Can you leave two stripes of sand when pulling away on a dirt surface with DCS off?
BONESTOCK (12-17-2022)
  #48
Old 12-15-2022, 02:45 PM
dbritt320's Avatar
It is an LSD. The final drive ratio is 3.31, it came out of a F-Type S donor vehicle.
HermanWiegman (12-17-2022)
  #49
Old 12-17-2022, 06:48 PM
dbritt320's Avatar
The picture you asked for.
HermanWiegman (12-18-2022)
  #50
Old 12-18-2022, 07:34 AM
Ahhh.. nice objective evidence.
In no way was this photo coerced or blackmailed from the owner.
I am going to purchase a -AA rear diff right now from eBay!
  #51
Old 12-18-2022, 07:41 AM
dbritt320's Avatar
In now way was this photo coerced or blackmailed from the owner.
I focused on the VIN. I made sure the VIN corresponded to an F-Type S ( https://www.google.com/url?sa=t&sour...Uqc4KlXBZ6u1_q ), then called the dealer to confirm the OE rear diff part number (TR24000) on that specific VIN.
  #52
Old 12-18-2022, 07:53 AM
Good trick.
I also did some VIN look up for parts from eBay to see if the donor car was an S model or not.
Not every used part listing offers the VIN, so it can be a crap shoot.
Too bad there is not some data base correlating the part’s tag number with the Jaguar parts catalog number.
That would make the hunt far too easy!
  #53
Old 01-06-2023, 06:34 PM
dbritt320's Avatar
Quick update ladies and gentlemen. Check engine light came on a while back. Got the codes scanned. Mostly Idle airflow codes, however at the very bottom there is one for output shaft sensor. Obviously that is the differential. Car still runs like a wet dream and has smoked everything I've come across (even keeping up will hellcats!). Im gunna live with the light until the feel gives me indication otherwise. Consider we have supercharger upgrades, a tune, downpipes, and LSD swap... I think this is gunne be feel it out and see. Absolutely no regrets still!
HermanWiegman (01-06-2023)
  #54
Old 01-06-2023, 06:38 PM
@dbritt320 Can you remind us of your LSD swap.. from what ratio to which ratio?
Thanks,
Herman
  #55
Old 01-06-2023, 06:41 PM
dbritt320's Avatar
Spoiler
  #56
Old 01-06-2023, 06:42 PM
dbritt320's Avatar
3.15 to 3.31
HermanWiegman (01-07-2023)
  #57
Old 07-08-2023, 09:13 AM
@dbritt320
Jump over to the "V6 Base LSD Swap" thread for more details. (link below)
If you are interested in the 3.31 ratio (or other gear ratios found in the F-Pace or XE/XF models)
Then the new Quaife ATB is probably your best bet, as we are setting it up to cover a wide range of ratios.
I can add you to our list of interested members. We may initiate an order in the coming weeks.
The historical approach is to find a F-Type V6S rear differential housing with tag number EX53-4A213-AA
These friction based LSD's are hard to find, and are often worn out after 30-50kmiles of driving... which is discussed in the below thread (about page 4)
/v6-base-lsd-swap-245971/page5/#post2649656
  #58
Old 08-10-2023, 11:40 AM
dbritt320's Avatar
I am definitely interested in the Quife ATB LSD!
  #59
Old 06-30-2024, 10:35 AM
spinningcog's Avatar
I just wanted to update the thread that I've had my helical diff from Herman installed in my F-type (6mt, base) for a couple of months now, and it has been great. Driving it home from the shop, I noticed an immediate difference in the confidence/predictability the car provides in low traction situations. The car maintains more grip and is more predictable, the traction control is much less likely to activate, since the car is much better able to put the power down. I would really recommend this upgrade, and working with Herman has been great.
Next up is aluminum y-pipe and cooling upgrade (Euro-Amp), catch can, and a pulley and tune,
-Will
The following 3 users liked this post by spinningcog:
DJS (06-30-2024), HermanWiegman (07-02-2024), HyltofWills (06-30-2024)
  #60
Old 07-01-2024, 06:52 PM
Crash808's Avatar
Does this work on the P300?
Quick Reply: Retrofitting LSD into V6
