Retrofitting LSD? Other Mods?
Old 12-03-2015, 01:52 PM
F-typical's Avatar
They take it to bits on arrival, inspect and clean each part, then put it on a shelf in a warehouse. Not a junkyard.
The climate here means leaving it outside is effectively very scrapping it...
Old 12-03-2015, 02:58 PM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
Yes, that's what our high-end "junk yards" or auto salvage companies do. I've never heard the term "breakers" applied to used vehicle parts businesses.
Old 12-03-2015, 05:16 PM
Received 4,454 Likes on 2,426 Posts
Breakers = Britain
Wreckers = Australia
Salvage yard = America
Second hand parts taken from vehicles being scrapped.
Old 12-03-2015, 07:31 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
I suggest that we all stipulate to British being the official language for this forum. So.........or dictionary as it were.
Old 12-03-2015, 08:41 PM
Foosh's Avatar
Sorry, can't sign up for that.
Old 12-04-2015, 09:17 AM
Unhingd's Avatar
Then you deserve as swift boot to the bonnet.
Old 12-04-2015, 10:19 AM
lizzardo's Avatar
Sorry, old man. We don't understand your banter.
  #28
Old 12-21-2015, 10:18 PM
f_in_seattle's Avatar
Originally Posted by ss23
Hi Guys,
I have a MY14 F-Type Base. After a year of driving, I'm feeling like I'm missing the LSD of the F-Type S.
Anyone have an idea if any third party manufacturer makes a LSD for the F-Type? Quaife only make an LSD for the XKR, any idea if this will fit?
In other mods, I'm also changing from the stock P-Zeros (have 19 inches) to the Michelin PSS this weekend.
I'm also looking to get a tune for the F-Type from my local tuner (they've worked with a lot of top-end vehicles and have stellar reviews so I have confidence in them) and I'm considering installing a methanol injection kit (tuner really advocates them, planning on installing a top-end kit with plenty of fail-safes to prevent any damage to the engine). Anyone have any feedback on any of these mods?
I also installed the Quicksilver exhaust and added some J-pipes to cancel the drone (I've taken 3 videos: before, without J-pipes and with J-pipes, am planning on uploading the videos tonight).
Sorry for the long (and a bit fragmented post)! Looking forward to any of the feedback and ideas of you guys! Thanks in advance!
Looking forward to those videos of the quicksilver exhaust. I have the base V6 as well and was wondering how much better the quicksilver exhaust would sound.
Old 12-23-2015, 07:21 AM
ss23's Avatar
Haha uploaded it after I saw this.
The exhaust is brilliant at WOT and idle but it was droning too much for me at a RPM of around 2k (doesn't befit a Jaguar). The J-pipes reduced the drone significantly without compromising the sound too much.
  #30
Old 12-27-2015, 05:05 AM
ss23's Avatar
@VMaxTuning, would you be able to help with this?
Adding the pulley, headers and a tune will create some serious horsepower for a car which already beggared belief that it doesn't have a LSD!
  #31
Old 12-27-2015, 08:42 AM
Foosh's Avatar
The "serious horsepower" being talking about in the VMaxTuning threads are on the V8s. All V8s have LSD std as does the V6S.
The only F-Types without LSD are the 340HP base cars, and somewhere a bit north of 400HP and perhaps 400 ft. lbs. of torque seems to be the reasonable limit for the V6s, which are both already putting out more HP/Liter (OEM) than the OEM V8s.
  #32
Old 12-27-2015, 10:00 AM
ss23's Avatar
You don't think that 400 ft lbs of torque with an open differential might be a safety hazard? Nonetheless, with extra torque throughout the RPM range?
This entire thread is based on the fact I have a base and I'm looking to add a LSD. I'm not sure you've read it entirely.
  #33
Old 12-27-2015, 10:51 AM
Foosh's Avatar
Safety hazard, no.
  #34
Old 12-27-2015, 12:07 PM
Unhingd's Avatar
...and somewhere a bit north of 400HP and perhaps 400 ft. lbs. of torque seems to be the reasonable limit for the V6s, ...
+1. Even with a +20mm crank pulley, I'm guessing the V6 will still max out at those numbers, but we are shooting for having that peak available over a wider rpm range.
  #35
Old 12-27-2015, 12:37 PM
VMaxTuning's Avatar
Former Sponsor
Safety hazard, no.
Lots of good info posted in this thread already by Foosh, Unhingd, and Cambo.
We haven't gotten to the diffs of the V6 cars yet so I'm really hesitant to say anything at this point other than in a world of open or ediff (those that use the rear brake on the rear wheel without traction to slow it) differential vehicles, you'd be amazed what a set of sticky tires will do for a non mechanical LSD car in and of themselves.
Being in the UAE I'd check into at the very least the latest gen of R compound tires if not a DOT legal drag radial.
  #36
Old 12-27-2015, 05:05 PM
Unhingd's Avatar
Safety hazard, no.
+1. A car with an open diff is actually easier to control: traction is lost on only one rear wheel if too much throttle is applied.
  #37
Old 12-27-2015, 06:53 PM
Safety hazard or not, open diffs suck, LSD's are awesome.
When I put the Quaife in my XJR it quite literally transformed the car for me.
The Jag was the first powerful RWD car I had with no LSD, it was certainly not as much fun without it.
  #38
Old 12-27-2015, 09:21 PM
Unhingd's Avatar
I concur. The only car ('02 MINI) I have purchased over the past 4 decades with no LSD, I retrofitted within just a few months.
  #39
Old 10-12-2020, 05:03 PM
Fast.Kitty's Avatar
Question
OK here are the part numbers which might help with your search:
Automatic, LSD, T2R4000 or EX53-4A213-MA
Manual, LSD, T2P1783 (I don't know the long part number)
Good luck
Sorry to resurrect an ancient thread, but as used parts are becoming cheaper it seems like this modification is becoming more doable. I was searching through online salvage yards and found a few differentials with the 3.31 final drive ratio but had part number EX53-4A213-AA and not ending in "MA" like quoted for an automatic car. Are we sure the automatic LSD version ends in "MA" and not "AA"? Also, I notice on some of the labels there is "YELLOW" added to it, does anyone know what this means?
I have attached a picture of the label of one of the particular differentials I am looking at adding for my 2014 V6 Base. This came off of a 2015 V6S Convertible Automatic AWD. Any info would be great!
  #40
Old 10-12-2020, 06:29 PM
Unhingd's Avatar
I hesitate to contradict Cambo, but this is what I have researched:
AA is T2R4000, the automatic version for the S (3.31 ratio). MA is T2R18657, the MT version for the base (3.15 ratio).
Quick Reply: Retrofitting LSD? Other Mods?
