Ride Height
Old 07-18-2015 | 09:56 PM
shift's Avatar
Yup, it's not so much that the car is low, it's the long nose!
Old 07-18-2015 | 10:11 PM
Unhingd's Avatar
Originally Posted by shift
H&K has springs that I believe gives you a 1" drop. I know 2 people who have installed them. Looks good.
H&R Springs offer a 1.2" drop on the V6 models and 1.3" on the V8 models. Velocity AP springs offer a .875" drop.
Old 07-18-2015 | 10:40 PM
Merlin's Avatar
My FTR isn't too low, but as has been mentioned before the AWD ride height is higher than the RWD models. You just need to be careful and angle your way into and out of places with steep inclines/declines.
Unless there is something different about the F-Type, you should also be able to raise the vehicle a small amount using the stock adjustment bolts if you really feel the need.
Old 07-18-2015 | 11:11 PM
AnD3rew's Avatar
Originally Posted by Mahjik
The main issue is with the nose of the car. There is a lot of distance between the clearance of the front scoop to the front wheels. Why this is a problem is that it means the the nose of the car can scrape easily before the front wheels are able to grab an incline (i.e. curbs, steep parking garage inclines, heaven forbid the car gets loaded onto a trailer, etc).
For the most part, the stock F-Type is not that low. It's mainly the nose distance which is the cause for scraping concerns.
Agree, there is no real issue with speed humps and debris on the road etc, it's short angles such as coming in and out of driveways that make it scrape. Mostly it is just the sacrificial plastic underskirt though and doesn't ever seen to do any real damage to the expensive bits.
Old 07-19-2015 | 11:46 AM
Nookieman's Avatar
+1
Old 07-19-2015 | 02:58 PM
Matrixband's Avatar
So, as I researched, the "approach angle" is paramount. A 911 has an approach angle of 12.1 degrees, the f-type reports in at 11.2 degrees. So, there it is.
I did find a reference to this neat device for driveways: Bridjit
Oh, here is a photo showing damage to the air dam. If that's the only damage, I can live with that.
Old 07-19-2015 | 03:24 PM
Unhingd's Avatar
Hard to tell for certain, but that looks like more than a 1.2" drop.
  #28
Old 07-19-2015 | 05:25 PM
Foosh's Avatar
I'm not sure it's dropped at all. It looks very similar to my '14. Have F-Types gotten taller, other than AWD models?
Old 07-19-2015 | 07:17 PM
Unhingd's Avatar
Foosh, yours looks like the standard 5.5" clearance. The R looks to be about 4" but that could be because of the much more aggressive looking splitter. The wheel gap also appears to be less, but that could be result of the view angle.
  #30
Old 07-19-2015 | 07:34 PM
Foosh's Avatar
Because of the shadows in that photo, you can't see all of the tire. After looking at the picture here, I just measured in my garage and from the top of the tires, I have 1.5" to the top of the fender lips. That appears to be about the same gap as the R in the photo above.
  #31
Old 07-19-2015 | 07:38 PM
Stohlen's Avatar
That splitter has been heavily bent downwards. This also explains why there are scratches on the top surface of the blade. Someone smashed that thing into a curb when parking for sure.
robbing
03-05-2024 10:51 AM
tlynch
12-31-2020 01:58 PM
37driver
10-04-2015 05:58 PM
Delta66
10-04-2015 05:40 PM
JagBrian
10-01-2015 12:52 AM
Quick Reply: Ride Height
