ride quality - 18", 19", 20" wheels
I test drove both V6 and V8 models with 19" and 20" wheels respectively. The low speed ride on the V8 was better than the V6.
But, the V6 was lacking the adjustable dampers.
I bought a V6 with 18" wheels, as I knew I could get a set of 19" or 20" wheels complete with nearly new tyres off eBay for less than Jaguar were charging (and I'd have 2 sets of wheels).
Having also bought and fitted a set of Gyrodynes, I can report that while the car can be unsettled by repetitive undulations at speed, the bump and rebound wheel control actually seems better. It now absorbs bumps on the first attempt, making me wonder about a mis-match between the tyres and the suspension when using 18" wheels fitted with the OEM Continentals.
I will throw in my 2 cents, as I too am looking at bettering my ride even though it's not too bad now, but I'm thinking the width of the tire will count also, just more rubber on the road. With the 2014 6s, I'm seeing that 295 rears will be my max and I. Think I saw 255's on front
And BTW, V6 vs. V8 , S or R, or model year, makes no difference, in terms of what tires fit. They all have the same wheel well, and hub dimensions. You can fit up to at least a 305 rear tire with no problem. As was said in another thread, some of the cars do have bigger optional brakes, but that's only potential issue if you were trying to downsize.
19" Propellers for Sale
If anyone is contemplating the move to 19" wheels or just want to have an extra set on hand and need new tires, please check out my classified: https://www.jaguarforums.com/forum/p...2/#post1279054
Part of the problem (confusion about what is "better") is that the tire is essentially the front end of your suspension. I've only got 142 miles on my 6S so far, but I find Dynamic mode on the suspension to be a little bouncy on our local roads. I think that there is too much high-speed compression damping for the tire and wheel combination. I haven't yet formulated an opinion on the rebound damping.
#30
#32
The beauty of these cars is that you can customize your personal dynamic mode and can dial back the suspension if you like while keeping the aggressive steering and throttle mapping.
#33
I'm hoping the dampers break in a little. The Bilsteins I fitted to my previous car seemed to have a break-in period of a thousand miles or so.
#34
#35
#37
Not trying to be condescending, just being sure I was clear. Some of our crumbling roads here stress the high-speed compression damping at low road speeds.
Wolfy
05-28-2024 08:06 AM
02jagstype
09-04-2015 08:20 PM
