Rim/Tyre/overall wheel size
Old 09-29-2016, 01:00 PM
obald's Avatar
Default Rim/Tyre/overall wheel size
Was cleaning my new(-ish) F-Type S Coupe last night and whilst doing the wheels noted the tyre sizes. I have the 20" Tornado rims and see that the fronts are shod 35/255 and the rears 30/295. The fact that the rears are massively wider than the fronts doesn't require reading of the numbers on the sidewalls or explanation, of course but why do the fronts have taller tyres? Doesn't this make the front wheels larger (in a diametric sense) than the fronts? Why is this desirable?
Old 09-29-2016, 02:23 PM
DPelletier's Avatar
That's not how it works; on a typical tire (P295/30/20), it is the treadwidth in mm, the height as a percentage of treadwidth and then the rim size.
35% of 255mm = 89.25mm height
30% of 295mm = 88.5mm height......close enough to be considered the same
Dave
Old 09-29-2016, 02:29 PM
obald's Avatar
Well, you learn something every day. Thank you very much.
Old 09-29-2016, 04:09 PM
nonsns3's Avatar
Dave
It is about the only thing in the world that is represented by three completely different units of measure: mm, percent, inches
Old 09-30-2016, 04:01 PM
DPelletier's Avatar
No problem. :-)
Cheers,
Dave
Old 09-30-2016, 04:06 PM
DPelletier's Avatar
Yep; very strange when you think about it.....still easier than the old system though; Tire Size Helper
Dave
Old 09-30-2016, 06:43 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
Dave
+1. Before the hybrid metric/English sizing, you couldn't calculate anything without tables . Now with simple multiplication and addition, it's simple to get a close approximation on most of the tire dimensions.
Daim
09-11-2016 03:33 AM
Drcummins
09-09-2016 09:36 PM
Asdrewq
09-09-2016 09:24 AM
James Tootle
09-03-2016 10:42 AM
davidboger
09-02-2016 07:51 PM
Quick Reply: Rim/Tyre/overall wheel size
