I have noticed excessive road noise which became all the more apparent on a recent trip over not so smooth pavement. Most of the noise comes from the rear tires and is quite loud. I'm wondering if the brand of tires (mine are Continentals) may be the cause or if this is a common problem across different brands and if anyone has encountered the same and what they may have done to address it--additional sound proofing perhaps?
How worn are your tires? Worn tires usually make a lot more noise than new ones.
I get a lot of road noise on bad pavement too. It's always been that way. I expect it's coming in the same way as the exhaust sound from the rear. If you're still running the symposer, you may not notice that as much because it gets drowned out by sound pumped through the firewall.
Mine is a base 2018 model and I don't think it has a symposer. If it does, I certainly can't detect any enhanced effects. My order detail sheet lists "LESS internal sound enhancement". Is that another name for symposer, and thus proof that it isn't so equipped?
What sort of cars are you used to? If you are coming from more luxurious GT type cars - the F Type has a lot more road noise transmitted into the cabin by comparison.
I traded a 2015 Maserati Ghibli base model with 19" wheels. Tires were Pirelli P Zero Nero that had 11K miles on them.
If road noise is common to the F-Type I'm wondering if insulating the rear wheel wells would be a solution and if anyone has done it.
I think that is indeed what that means, but hadn't heard anything about that. I find it interesting that it's now optional, because I'd have opted out in a heartbeat.
All V6 and V8 F-Types had the symposer but maybe now it's an option on at least the V6?
Anyway, I also find there is a fair whack of road noise from the rear and I reckon most of it is coming through the rear wheel arches.
I tried to buy a can of spray on sound deadener about a year ago with the idea of spraying it on the rear wheel arch liners, but the sale fell through.
I don't know if it would have made much if any difference but I thought it would be worth a try.
I have also thought about removing the rear wheel arch liners and sticking sound insulation matting on the undersides, but it would have been a tricky job, expensive, and I was worried that the arch liners might not go back on nicely, so I never got around to it.
I might look into the spray on idea again.
i can confirm mostof the noise, like 70%, is coming from the rear.
i lined the whole trunk with both sound deadening and cotton sheet (whatever they are called), plus felt tapping most hard contact trims, it has brought the luxury back into the F.
One downside is the exhaust note is also subdued considerably, but that’s not really a con all things considered, one can always crack the window a lil bit for the full glory.
Aside from standard locations like the doors, i have also slathered the front wheel liner with said materials, though i don’t think i have got that much benefits from it.
Rear wheel liner hasn’t been done, i doubt it’s gonna make a lot of difference, if at all, since the inside has already been covered.
Wheel liners are easy, drop the wheels and that’s it, some sort of sound insulation already present in the wheel well.
To get to the inside, it’s a bit more involved, the trunk side pieces are the last things to come out, search for lowering spring/audio build for more info, every trim has to come out for full access.
You will get better results using a sound absorbing material like in the link below in the open areas behind the rear panels. Materials like dynamat are designed to reduce the resonance and vibration of the panel it is attached too, not absorb or block the sound. It's not the same as sound absorbing material like Fibermat or sound barrier materials like mass loaded vinyl. Those thick foam blocks in the rear corners are sound absorbers for example.
Which material would be best if you can only lay one more layer after sound deadening?
And is there any practical difference between sound blocking and sound absorbing? And what the hell is decoupling?
Sound blocking is what you use a mass loaded vinyl for but there can to be no gaps in the vinyl barrier between you and the sound source. Decoupling is where you prevent sound vibrations from passing from one material to another. Sound absorbing material like fibermat convert sound passing through it and dissipates it into heat energy. Resonix Sound Solutions website has tons of information to get you up to speed on the different types of materials and how they work.
For me, this was a VERY WORTHY project, and yes, I likely did go overboard with the Dynamat, but I felt better with more of it on the car rather than it sitting unused in my garage.
We enjoy and drive these cars for the sensations and the emotions, the sound being one of them.
I've reduced the bad sounds so I can better enjoy the thrill of the good sounds !
Photos to follow.
BEST !
RWS
