Rock stuck between window and door trim
I have a rock that is stuck in the door window seal/weather stripping that is causing vertical scratches on my window if I open and close it. Does anyone have experience clearing debris on from this area? Is there an easy way to access and clean out this compartment? Thanks
I followed the TSB to get the weather stripping removed. Used compressed air and a vacuum to get the inside seal. It fixed the problem. Now time to deal with the scratches. I recommend actually taken the weather stripping out as its super easy to take in and out. Fishing out the rock, I think is harder.
mjh097
05-24-2022 09:27 AM
Jaguar XK8er
08-21-2018 01:29 AM
Sean W
08-20-2014 12:16 AM
