Roof Antenna
Old 05-19-2023, 07:19 AM
fishst's Avatar
Many thanks for your reply and pointing me in the direction of OzFXR.
Guidance found on P6032 of the manual.
A job for the weekend.
Maybe I'll take some photos and write it up for others.
Thanks again.
Old 05-19-2023, 07:45 AM
OzXFR's Avatar
Received 3,226 Likes on 2,380 Posts
Thanks again.
Pray tell who is this OzFXR of which you speak?
Not your fault of course, all down to the previous poster Steve/lizzardo.
Old 05-19-2023, 12:35 PM
fishst's Avatar
My apologies.
The great news is that I found you and now have some guidance.
I'll have a good look at the weekend.
My intention is to get the old one off, plug in the new one to see if it then works, take the old one apart and if that's simple take the new one apart to use the already painted cover.
We'll see!
Old 05-19-2023, 12:42 PM
lizzardo's Avatar
That guy? He can be a real knucklehead sometimes (with sloppy typing).
OzXFR (05-19-2023)
Old 05-19-2023, 04:31 PM
scm's Avatar
scm
scm is offline
Received 1,482 Likes on 1,122 Posts
Aren't you going to blame auto-correct?
Old 05-19-2023, 08:03 PM
lizzardo's Avatar
It was autocorrect that changed "fine gentleman" to "knucklehead."
The following 2 users liked this post by lizzardo:
DJS (05-19-2023), scm (05-20-2023)
Old 05-20-2023, 07:29 AM
fishst's Avatar
It's done! Not as difficult as I imagined.
Car is a 2016 F-Type R AWD coupe with lots of extras.
Tools I used:
T6 & T8 driver,
10mm socket,
75mm extention,
Flat Blade Screwdriver,
Piece of rubber sheet.
Bought new part
Cost £85 net.
Open boot and remove plastic covers from both sides near leading edge
Not the best pic!
Undo the 6x 10mm nuts, 2 each side and two on the leading edge (short extension needed for those 2)
Pry up edges carefully and using flat head screwdriver (with rubber to protect) pop out the four retaining clips (2 each side)
Panel is now free.
Unplug the wiring. Pull up the white clip on each plug until it clicks then remove from socket. Need to rotate plugs to do this.
Unit is now free. Undo two 10mm nuts holding antenna pod to panel, squeeze black retaining clip to release.
Replacement is the reverse of above.
I went slightly further as the new part comes unpainted.
I removed the PCB from the new one (8x T8 screws) and fitted it into the old housing.
New one did not have the rubber bit on the top of the board so removed it from old one and used it again.
You can see where water has affected the board in places (right hand board above and below).
Couldn't resist looking at the other side of the board (T6 needed for this)
Solder joint for GPS has gone bad.
This is a cheap board!
Started at 10:10 and all done and packed away by 11:20 including a coffee break.
Fired up the beast and after a few minutes, red line through GPS symbol went away and car showing in its correct location.
First dealer I spoke to about replacing this wanted £500, second said they'd have to run diagnostics first at a cost of £180.
I thought I'd take the chance and it appears to have paid off!
Hope this helps anyone else who has same issue.
The following 6 users liked this post by fishst:
DanL (05-29-2023), DJS (05-20-2023), OzXFR (05-20-2023), Rondog (05-20-2023), scm (05-20-2023), Thunderjet Racing (05-21-2023) and 1 others liked this post. (Show less...)
  #28
Old 05-20-2023, 07:48 AM
DJS's Avatar
DJS
DJS is offline
Received 2,112 Likes on 1,410 Posts
Nice writeup!
Old 05-20-2023, 08:25 AM
BritCars's Avatar
Hi fishst - what was the issue you were solving? No gps at all or intermittent?
I have a strange issue on my 2017 SVR. It shows me parked about 3-4 houses over from where I am. Always about 300ft or so to the east.
And if I pull up the map using the App on the phone of a recent drive around town on our Land Rover it tracks the route directly down every road. On the F Type app I see it wandering on and off the roads, sometimes snapping to the next road over for a while then apparently driving back through buildings onto the correct road again
Had the dealer check it out under warranty a couple of years ago and they couldn't explain it. I didn't pursue it as it doesn't really matter - just a bit odd. Wondering if gps issues are common here?
  #30
Old 05-20-2023, 08:43 AM
fishst's Avatar
Hi BritCars
Started off as intermittent and then more and more noticed the "No GPS" symbol appearing until it was on all the time.
Car was still tracking about but in the wrong part of the country so I assumed the telematics were still providing info and it was the GPS antenna as had read this is a common problem.
For the sake of £85 I thought I'd replace it but couldn't find a write up.
Having taken it apart I think I got it right. Bit of a guess though.
  #31
Old 05-20-2023, 10:40 AM
Rondog's Avatar
Good job! Thanks for posting pictures and procedure!
  #32
Old 05-20-2023, 11:05 AM
scm's Avatar
scm
scm is offline
My car always seems to be "parked" a couple of houses away from mine, and I've experienced the "not where I am" while driving once since 2018, so not a frequent occurrence for me.
  #33
Old 05-26-2023, 12:11 PM
fishst's Avatar
Just back from a 650 mile trip into South Wales, Brecon Beacons, Black mountains, up to Snowdonia and back through the Cotswolds.
Awesome scenery. "A" roads rather than motorways.
Back up was phone (didn't use) and OS maps (used to plan the best driving route).
GPS spot on all the way! Even what side of the road I was on.
Happy days.
scm (05-26-2023)
  #34
Old 05-29-2023, 09:47 AM
soaringeaglers's Avatar
Default Antenna
No one has answered about what the convertibles have for an antenna, since it's not on the roof. Does anyone know?
  #35
Old 05-29-2023, 10:01 AM
CJSJAG's Avatar
AFAIK, my convertible has no antenna.
The cloth roof allows normal signal strength for my cell phone and internet access.
No Faraday cage!!!
  #36
Old 05-29-2023, 10:15 AM
No Faraday cage!!!
Well thanks, but that makes no sense! I'm sure your Jag came with factory radio, GPS and satellite radio. It needed to have an antenna to work!
  #37
Old 05-29-2023, 10:20 AM
CJSJAG's Avatar
When you find it, let me know!!
I am guessing that the components you are referring to have built-in antennae and do not need an external antenna when they have clear sky access.
You do not need to carry around an antenna to use your cell phone, do you??
Plus, if JLR was able to hide it so well, why would they not do the same for the coupes??
  #38
Old 05-29-2023, 10:26 AM
Thunder Dump's Avatar
The convertible antenna is located under the luggage compartment lid in the Sigma Pod. In the North American market, this is for GPS, satellite radio, and most of the digital (HD) radio services (including analog FM and AM):
The live traffic antenna is located under the top of the instrument panel.
  #39
Old 05-29-2023, 10:34 AM
CJSJAG's Avatar
Do you mean built into the lid of the small center console?
  #40
Old 05-29-2023, 10:35 AM
Thank you! I figured there had to be an antenna somewhere. Those components are buried in metal. It would be like putting your cellphone in the glove compartment and expecting it work as well!
Quick Reply: Roof Antenna
