Rotor Replacement
Rotor Replacement
Sorry, I know it was duscussed before, but with the spacers coming I decided to replace my rotors and pads with some drilled and slotted ones. Can someone tell me the procedure to disengage the rear electric brakes, with my xkr I just put it in neutral and disconnected the battery to reset the pad depth. Thanks in advance.
So if I'm reading this correctly there is no way of changing the rear pads and rotors in the maintenance mode or manual caliper release without using the Jaguar approved diagnostic equipment.
In the maintenance mode you can't deactivate it, but they give you a deactivation sequence, and in the manual mode you are not able to recalibrate the epb.
Received 3,209 Likes
I got the rear pads changed a couple of months ago, and there was no need to put the parking brake in maintenance mode, although that may have made it a fair bit easier to push/wind the brake pistons back in, see this post and #59 after it: https://www.jaguarforums.com/forum/f...3/#post1557910
