Rough starts
Rough starts
Have any of you had an issue with rough/misfire startin when cold? Before I call my server manager (who has been amazing) and drop it back off. It has never done this before I just had major engine work done under warranty, and drove it to keywest from MA with zero issues, other then the AC not blowing cold, dropped it off they took care of it, now the last 2 cold starts after sitting, it will fire right up and idle rough then stall. I can keep it running with alittle peddle and eventually it will gather itself and run fine. Any ideas before i drop it back off again (3hrs of driving)?
15 V8S
15 V8S
CEL finally showed up:
P2180 - System Too Rich Off Idle Bank 2
P2178 - System Too Rich Off Idle Bank 1
P2190 - System Too Rich at Idle Bank 2
p2188 - System Too Rich Off Idle Bank 1
once warm, runs mint. Reset codes 2x come back after a few starts. 3 tanks of fuel, bottle of dry gas in the 2nd tank.
Any ideas?
Any ideas?
Search this for the codes - it describes the various faults that could cause them...
https://www.dropbox.com/s/1ek33ux7tf...guide.pdf?dl=0
Itismejoshy (04-24-2018)
Any ideas?
Any ideas?
Time to bring in the pros.
Thanks for this!!
Thinking its MAF or injector related, being that its on both sides i would lean towards MAF, but i dunno. im just going to drop it off at this point. thanks for the insights.
Received 3,226 Likes
If it's on both sides then it's unlikely to be the MAF sensors, as there are two of them one on each intake tract and they would both have to fail in the exact same way at the exact same time.
I believe there’s one in the intake tube leading to the SC. I got a similar set of codes when I pulled off the intake crossover tube. Fabulous SC whine, though.
Down at the bottom of parts 5 and 6, in the "resonator" tubes and just above the air boxes. I am 99% sure there is no other MAF sensor anywhere, maybe you are thinking of the MAP sensor?
Also, that pic confirms there are three L shaped resonators on the upper part of the intake tract, one each on parts 7, 8 and 9.
There are definitely two MAF sensors, one in each intake tube, see this post: https://www.jaguarforums.com/forum/f...8/#post1878841
Ah, but that won’t account for the rough idle.
