royal purple engine oil
I am assuming you mean in an F Type. If so, engine oil is supposed to meet JLR specifications, STJLR.03.5004. Only a few engine oil brands make a version that meet these specifications and it will be on the label. I have no idea why JLR products needs these specifications or if it makes any difference. I buy oil that meets STJLR.03.5004 since that is what is recommended.
The Red Line is Dexos1Gen2 which is a benefit (reduces LSPI or Low Speed Pre Ignition, a common characteristic of GDI engines).
I suspect that Red Line doesn't choose to pay for manufacturers' certifications, but you don't know for sure, do you?
![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
Received 3,209 Likes
If you are willing to spring for that fairly expensive Royal Purple you should instead go for a 0W-20 ILSAC GF-6A oil, the RP you show is only GF-5.
Plenty of info on the web and some on this forum about the newish ILSAC GF-6A (you don't want 6B which is ultra low viscosity 0W-16 meant for hybrid engines).
Judging from the info on the web the problematic timing chains on our AJ133 and AJ126 engines will benefit from using ILSAC GF-6A oil.
I asked as a local dealer has it for $35 for 5l
I'm getting ready for my first oil change, What are the common oils which members here use?.
I imagine most of the research has been done by 6 years of F type forum users already, and oil selection is not my knowledge base, other than wrong oil can be bad!.
I change mine every 3000 miles so im not looking for the high price champagne of oil
davidladewig
09-02-2017 11:56 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
