Rubber by Treadplate Pulling Away
Mine is doing the same. There are small plastic pins that insert into holes in the metal of the body at regularly spaced intervals. Some of mine are broken or the hole the rubber sits in is cracked at the edges. Some of the pins were pushed into the rubber. In short, either need new pins or new weatherstrip that hopefully includes pins. If your pins and rubber are not damaged you may be able to reset the pin in the rubber and snap back into the holes. Unfortunately this will likely reoccur even with a replacement piece. I posted on this about a month ago but didn't get a response other than Unhinged asking for a photo of the pins. I was thinking of maybe using an adhesive but wasn't thrilled with the idea of smearing up the body. Maybe a dab in the pin holes of an automotive adhesive or a thin 3M peel and stick. Any suggestions welcome as I was contemplating this just yesterday. Leaning towards a 3M tape, but haven't researched.
CRS 123 (07-09-2018)
Mines the same; 2-3 pins are broken and the weatherstripping is torn at the plastic pin location. The only decent solution I see is a new weatherstrip and new plastic pins.
Dave
IME the double sided tape doesn't work well with rubber. 3m makes a trim adhesive but frankly I think that's a little "duct tape and bailing wire" solution for a $125,000 car. I bought mine CPO so I don't know if I did it or the PO did, but I'm going to replace the offending parts and then it will be like new again.....then I'll be more careful! :-)
Cheers,
Dave
Cheers,
Dave
Cheers,
Dave
Cheers,
Dave
CRS
NTL1991
XJ40 ( XJ81 )
09-10-2015 12:56 PM
