Rubbing Problems (2015 R Coupe, HR Springs, 17mm spacers)
Looking for some input on resolving this. As titled, I have some rubbing problems with my 2015 R Coupe, only apparent when going over sharp dips in the road, but bad enough that it's caused some fender damage. I'm on gyrodynes (i think that's the name of these wheels?) H&R springs, and what I believe are 17mm spacers. I was not the original person who installed this setup, and the one who did install them did not recall the exact size of the spacer. I did a very unscientific measurement with some painters tape in order to measure the spacer and it seems to be closer to 17 so that's the number I'm going with. As it stands, my options are to either go back to OEM springs (not preferred since I like this look and ride feel), shave the fender (50/50 on this since it's permanent modification and having cut fenders means slicing the tire if it doesn't actually fix the issue), or changing to VAP springs. My question on the VAP springs is whether or not the additional clearance is enough to ensure I'm not bonking the fender anymore. From all the other threads I read, the difference between VAP (.75"-1.0") and H&R (1.25"-1.5") is only half an inch. Is that enough to squeeze me out of this?
Edit: Realized now that I should have referenced that last picture to the floor... I'll retake it after work.
I don't think either of your spring change options will work. The wheel will still move through the same arc regardless of springs, you'll only make it more or less common to go to full compression.
I'd recommend Option 4 out of the three you list. That'd be changing spacers. I got some spacers in a group buy but sold them without ever installing. At the time, there was discussion of 15mm vs. 17mm, and that the 17s might cause clearance issues but that 15s were safe.
EDIT: Here's the group buy discussion I was thinking of. There are several others you'll find if you search for "wheel adapter group buy".
https://www.jaguarforums.com/forum/f...pacers-194739/
Whalesmash (01-11-2022)
Two things going on here with your car. H&R dropping more than the VAP...AND then you pushed the wheels/tires out 17 MM as opposed to 15 MM.
Not sure of exact measurements and geometry...BUT I know that 15mm with the VAP drop (.75-1") WILL NOT rub. And I drive on likely some of the Sh***tiest roads in the US.
My Ford Raptor even bounces around on these roads, and the F-Type has never rubbed. Just FYI.
Good luck.
DC
With VAP Springs and 15MM Spacers on all 4 Wheels
Good luck.
DC
The 17mm is a thing because the wheel studs paired with some of the OEM wheels won't clear with 15mm spacers. You can, however, shave down the wheel studs as there is at least a quarter inch of non-threaded length on the end of the studs, and go with 15mm spacers.
Appreciate all the input so far everyone. If I do go back to stock springs, do you think the extra 1-1.5 inch of clearance will give me enough room to not worry about rubbing? My concern is that the extra throw should give me more buffer zone, but that doesn't necessarily mean that I'm less likely to rub as the spring rates might be different? At this point I'm willing to forgo the drop and keep the spacers but I feel like keeping it dropped without spacers would look really odd.
I do think at regular height the 17 MM would likely clear with no issues.
Good luck.
DC
Alright, looks like there's been a few suggestions here saying that the switch to 15mm would be the way to go. I'll go ahead and put my order in. I was originally quite skeptical that 2mm is enough to give me the clearance I need but with this many individuals saying it will work, I'll take the leap. It's only a few hundred bucks and a bit of my time. Thank you all again for the replies, I'll keep you updated when things arrive and I have a go at it.
I don't think static ride height is the thing to look at unless the spring is limiting travel. Higher ride height just means that it'll take a bigger bump to compress the suspension to the rubbing point.
15MM to 17 MM = a whole 2 MM like this __
DC
Would agree if the tires went straight up and down vertically...But they typically sway in at the top when compressed (Negative camber on compression), so the tops would tilt in as it compresses and that is why I think it will be fine. In fact, if that did not occur, my tires would rub with 15 MM...I count on them tilting in at the top a little on bumps. Sounds like he is going with 15MM anyway, so a moot point...But that is why I felt/feel they may not rub. Kind of like this...(Not exact)
DC
DC
Therock88 (01-14-2022)
The following 2 users liked this post by DJS:
powerhouse (01-15-2022),
TheDrainPlug (02-18-2022)
Edit: Looks like these might be the ones for my model? Hmmm, another possibility... Link
Another Edit: Read another thread about Eibachs not fitting well. Probably don't want to deal with it, haha. On another note, VAP does not list their F-type springs anymore on their site. Are they discontinued or something?
Michelin PS4S 295/30/20
I use WD40 and steel wool but there are many ways to clean them up such as a wire brush or a whizzy wheel on a drill.
