Running extra quart of oil for track
Hey guys! Planning on tracking my 2016 F-Type R for the first time this weekend and I wanted to do an oil change before I do. My buddy runs a N54 powered BMW and his track buddies recommend adding an extra 0.5 to even a full quart for track to ensure the oil pick-up doesn't run dry on long sweepers. Was hoping for some advice on if that is a good idea for the F-Type too.
Amit Patel (04-21-2021)
When you add too much oil, the excess oil will go towards the crankshaft, and as the crankshaft rotates at a high-speed, the oil is mixed with the air and ‘aerates’ or becomes foamy. This foamy texture of the oil acts like a bad lubricant, and the oil is not pumped effectively. Over time, the engine will be starved of proper lubrication
The following 2 users liked this post by zach05855:
Amit Patel (04-21-2021),
JacksonvilleJag (04-22-2021)
Amit Patel (04-22-2021)
NOTE!!! I am not saying to run too low. I'm just saying too much oil is a bigger problem than too little oil to a point. Obviously, running way too low will be catastrophic, too.
Run the exact right spec. Run what Jaguar recommends.
Received 3,209 Likes
From the AJ133 Technical Training doc:
"Reduced oil foaming • Structural baffle plate".
Carbuff2 (04-24-2021)
I suggest flushing brake fluid and servicing brakes prior track.
Also, don't over-inflate tires - as you drive tire temperature (and pressure) will go up. If you start at 38 PSI after few hot laps you might end up as high as 45. If tire pressure gets too high, tires will start losing grip.
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/931x734/capture_945409d40d569f6e44afdf955c0436e1239103bf.jpg)
Its easy:
track driving with high-G forces, heats up the tires more.
High speed Autobahn driving doesn't increase pressure as much. BUT stability is better with less sidewall flex. <--- which I'm sure isn't much with 20" wheels![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
The important thing is 'hot' tire temperature. On our other car, the manufacturer specifies a higher COLD inflation on street6-driven situations, but suggests letting air OUT (cold) for track.
If you ever watch NASCAR, they start low after a tire change, with the front splitters dragging until the tire temps increase.
Dwight Frye (04-24-2021)
