Safe jacking points
1200hpgarage (04-23-2024)
On the rear, the arrow points to the mounting plate of a suspension piece. On the front, there's a flat metal chassis structure behind the arrow.
Buick and I were posting at the same time. There's absolutely no need to jack the car to install the Sto-n-Sho.
mjm3457 (09-24-2015)
Thanks guys. Obviously I haven't looked under there myself. I am at the point where I don't bend very well anymore, and thought I needed more clearance to get to that bolt. But I'll get onto this job now with your input. I just received the title transfer from the dealer so can now apply for my plates.
A stubby Phillips screwdriver will take the OEM plastic center fastener out, and a 10mm socket is all you need to install the stainless steel bolt that comes with the Sto-n-Sho. It is literally a 5-minute (or less) job. It takes more time to fasten your plate to the removable part of the bracket.
This thread has pictures of what the jack points look like and where. The diagram in this thread might not be right. I used these to put on the porterfield pads.
https://www.jaguarforums.com/forum/f...-127665/page2/
jv9344 (01-30-2018)
Rlover
03-30-2016 10:04 PM
