SC pulley needed in So Cal
Hello, I bought the pulley from Vmax and it doesn't fit. Their pulley is too small for my '15 R so it was bent upon installing and removing it many times. Long story short I need one ASAP. I don't care if it is for a V6S or a V8R, oem or not, but I need one. Anyone???
The upper reduction pullies from any vendor are too small by a little bit. A bit of grinding is needed to polish the casting irregularities in the housing snout. Also, the pulley needs to be superheated before it is pressfit onto the shaft.
Pullies can be acquired from Eurotoys or Mina Gallery.
If you have a V-6 don't bother with the upper pulley...go straight to the crank pulley. There's only a 1.5 mm difference between the OEM and the reduction pulley.
Eurotoys (02-27-2016)
Try http://http://www.ecutuninggroup.com/ they might have an OEM take off , they are in CA. Good luck!
Here are your two options. I believe Eurotoys option is a better deal since it is less expensive and offers a test dummy pulley for test fitting before you install the real one.
http://www.eurotoysltd.com/catalog/p...133mlag9jr6ja7
http://www.minagallery.com/jaguar-f-...ulley-upgrade/
Jaronstoys (02-27-2016)
