Seat damaging the bulkhead
Old 07-11-2016, 11:43 AM
DPelletier's Avatar
Just FYI; I have those longer hangers too and though my seat hasn't been damaged, the seat back has ripped the rubber on the hook.....I know you said they were going to set it but unless they set both the base and angle, it may still hit.
Dave
Old 07-11-2016, 01:00 PM
Adz3000's Avatar
Yeah i think i'll just be making sure i keep the seats away from it for now haha
Seems the base is set to now cut out if to far back but like you say if the angle of the seat is to reclined then yes it will still reverse into the bulkhead. Although now with this longer hook it will only damage the hook and not the finish on the the bulkhead.
Thanks to all for the input
Old 07-11-2016, 01:11 PM
Arne's Avatar
Good result! Glad you got it sorted
Old 07-13-2016, 04:54 AM
jaguny's Avatar
As this problem has been successfully analyzed and solved (good work all), I thought I'd throw out another "passenger" problem: when some passengers get out they scrape their shoes on the vinyl threshold trim along the bottom of the door opening, scratching the vinyl. Also, sometimes hitting the speaker or lower part of the door. Short (pun intended) of only allowing those with short legs has anyone dealt with this issue? I was thinking I may need interior xpel or something protective?
Old 07-13-2016, 06:01 AM
RickyJay52's Avatar
Received 1,603 Likes on 861 Posts
Hey jaguny. Unfortunately I think that that happens to all of us from time to time (it even happens to me every now and then). How about my wife shutting the door with the seat belt in the way? That was good for a couple of nice, if small, nicks in the sill. S*^t happens.
Old 07-13-2016, 07:03 PM
jaguny's Avatar
Smile
Hey, you guys solved the other problem nicely. I am respectfully rejecting your reply
Old 07-13-2016, 07:09 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Well...I certainly wouldn't recommend wrapping the speaker grille.
As that grille includes the entirety of the problematic area, I'm certain there is not much you can do. If the issue is further back, you could cover the panel section just below the door pocket.
  #28
Old 07-13-2016, 07:25 PM
jaguny's Avatar
I think the bigger issue is the black plastic threshold. I wonder what it would look like sprayed with black plastidip or I could insist passengers take off their shoes.
Old 07-15-2016, 12:26 PM
Uncle Fishbits's Avatar
Dave
I thought it was my dry cleaning that did that, but the top of the rubber has ripped off in mine, as well. It's dangling and hanging on, but I can't use it so I bet I just rip the rubber part off and call it a day.
This is what is called a design flaw.
  #30
Old 12-22-2017, 09:40 AM
ndabunka's Avatar
Originally Posted by Adz3000
Thanks for the input, at least i now know that it's not a issue with the seat motor stops and it could potentially do the same to your car.
You would think they would be tested and designed to not cause damage at all. There is obviously some design consideration as the seat fits round the coat hook when moved to the rear.
Unfortunately, this is not..'exactly' accurate. While the designed space in the rear of the seat "can" move around the coat hook, it can only do so IF and when the seat is raised substantially higher than a "normal" seating position. With the seat in it's lowest position essentially sitting on the floorboards, there appears to be over an inch and a half of space between the seat and the bulkhead behind the seat. Those with longer legs will want to "reclaim" that space. (See attached images)
This limitation appears to be due to the design of the "coat hook" pushing the seat back forward due to the seat back design (e.g. the gap does not extend high enough on the seat to permit the hook space so... the hook just ends up pushing on the back of the seat forcing a more upright position that would be ideal).
My question is "Has anyone REMOVED that pesky coat hook all together so that those of us with long torso bodies can have the seat at its LOWEST position AND also have it pushed all the way back"?
PS - After reading the balance of the posts in this thread I decided that removing it would be... shall we say.... "un-wise".
After a fair amount of time tweaking the settings I think I have recovered a lot of the empty space behind the seat without having to raise the seat any higher than necessary.
Attached Thumbnails Seat damaging the bulkhead-pushes-back.jpg   Seat damaging the bulkhead-fully-inserted.jpg
jaguny (12-22-2017)
Philly Single
07-17-2017 03:53 PM
jaggedy
04-10-2016 10:07 PM
joejag05
04-04-2016 09:17 PM
sanchez
04-01-2016 10:55 AM
grantorino62
03-29-2016 01:56 AM
Quick Reply: Seat damaging the bulkhead
