Seat inserts - removal / replacement
Old 03-05-2021, 07:12 PM
gg2684's Avatar
Originally Posted by bjg625
Mirror is not cover but replacement took 10 min for both using the pry off tools.
thanks, that’s what I thought too but the previous post indicates otherwise.
Old 03-06-2021, 05:34 PM
bjg625's Avatar
I put a small piece 2 sided tape on inside corner but I'm not sure it really needed it.
Old 03-07-2021, 12:32 PM
BenFT's Avatar
Without the tabs like the OEM mirror cover has it will not stay in place. It can easily be removed with a gentle pull. My concern with the Koshi covers were in the event I needed to remove them I might encounter problems because of the strength of the needed additional adhesives. I have in clouded a picture of the Koshi covers next to the OEM mirror covers. Without those tabs the mirror covers will not remain secured.
Old 03-07-2021, 02:09 PM
gg2684's Avatar
Question
so are you planning to use double-sided tape to install or take your chances without the factory tabs?
Old 03-07-2021, 02:28 PM
BenFT's Avatar
[QUOTE=gg2684;2362354]so are you planning to use double-sided tape to install or take your chances without the factory tabs?[/QUOTE
The story goes like this: i had first purchased several Koshi interior CF parts and was very pleased. I then decided to order several exterior CF parts. I luckily made all the purchases thru Madness Auto Works.
Prior to my purchase MAW only carried a select assortment of Koshi Interior CF parts. They agreed to start carrying more of their parts and I was the first to order the following parts from them : Mirror covers, Radiator surround, bumper cover and the bottom front center lip. Koshi provides little to no help with the installation. When I tried to install the parts none of them fit correctly. I sent several pictures and videos to MAW and they agreed. They were kind enough to take all the exterior parts back. So the short answer is that did not install them. Instead I purchased the Jaguar covers and they fit perfectly.
baloozman
12-31-2021 11:40 AM
aceler8
11-30-2021 11:38 AM
autocad23
06-06-2021 09:38 PM
96x300
12-24-2018 05:12 PM
hoodun
10-12-2015 10:41 PM
Quick Reply: Seat inserts - removal / replacement
