Seatbelt Question
Seatbelt Question
Hello All,
I took delivery of my F-Type coupe P450 (left hand drive) a few days ago, and the only issue I'm having is with the seatbelt. It's cutting into my shoulder quite badly. I purchased a seatbelt covering pad for it, but it hasn't made a difference. Has anyone got any advice or a pad you use and like that you could recommend?
Seat belt pad
I had good luck with this one: https://www.farmandfleet.com/product...d-cushion.html
Though it was more for the shoulder belt sqeaking/rubbing on the seat back.
Let me know if you have trouble finding one.
Maybe what works for me will also work for you.
I found that the seat belt on my MY 2015 F-Type rode far too high up on my neck and it was really annoying.
I tried a few things but the final solution I still use to this day is a large zip tie over the top of the seat strap to firmly hold the seat belt down to the lowest point of the strap, see the attached pic.
Yes I know the 2022 seats are different but they still have a similar strap so maybe that would work for you as well.
And of course mine is RHD but it would work the same on LHD.
