Service bulletins
Service bulletins
Got my car back after it's yearly check-up. While it was in, I had the dealership address the service bulletins for the fuel filler neck and the stereo rattling. Took longer than I would have liked, but the results were worth the time spent driving the loaner. Gassed up the car this morning with nary a shut off (never had that happen before) and for once the body panels remained quiet while I listened to music on my drive to work. It didn't solve the quality of the sound, but no more buzzing.
Can you please list the exact service bulletin they used for the audio rattle issue? I would love to fix mine, and a couple months ago when I took my 16" R in, they said they didn't have any bulletin for it and couldn't fix it...
See post #14.
https://www.jaguarforums.com/forum/f...ut-now-151130/
Mine is going in this Tuesday for speaker fix. I'll post bulletin number once I get the service sheet back.
MeanKity (04-02-2016)
They still have it since last Wednesday when the battery died. Am being told I'll have it back tomorrow hopefully. Service rep said battery was holding a charge and did not need replacement. As I mentioned, they said my car had the TSB fix at the factory. The problem has been identified as a bad amp. We'll,see as the new amp had just arrived when I was called with the update.
Have my car back. They did not replace the battery as they said it held a charge. They also replaced the amplifier in the stereo. From what I can tell the rattling speakers have subsided but I need more time with it on a wider variety of music. I am thinking the plain stereo setting may end up being best or possibly dts. I will be missing the B&W system in my XF. I missed the R and glad to have it back, no explanation why needed. I'll update when I can spend more time with the stereo.
Do you have a rough price quote? I'm considering doing this on my MY 16 R, as the poor speaker quality and particularly the rattle is starting to really bother me.
Yep. I'm also looking at going after market after much back and forth with the dealer and a JNA case number (which they closed after a month, as audio working according to spec). Crap spec.
Agree. If you truly want to be happy then you will have to go aftermarket. Make sure you buy quality equipment or you won't be happy at all. The key item that people overlook is the processor. Make sure you find a good quality processor and match that up with a great set of 3 way component speakers. Also, recommend sound dampening material around speakers to reduce/minimize any rattling.
The dealership will have to run the VIN# through the Jaguar database to determine what recalls and service bulletins have been performed on the vehicle. You should be able to call any service advisor at your dealer and give them your VIN# and they could look up the info and you shouldn't even have to go there physically.
