Service Message
Service Message
The handbook for my 2021 R-dynamic indicates service at 16K or 1 year, which ever first.
I have the car booked in January for the 12 month service at about 9.5K miles, basically just oil/filter..
So, today, on start-up I got a message saying service due in 1,400 miles (ie 10K miles).
Seems like the car is in conflict with the handbook!!
Received 3,259 Likes
Lots of discussion and evidence that the 16k miles oil change interval is too long on both the V6 and V8 and you should change the oil and oil filter twice as often as that so every 8k miles at least.
Easy enough to DIY an extra oil and filter change between each dealer/scheduled change and as long as you use the correct spec oil it won't void your warranty.
Just get a vacuum/extractor pump, at least 8 litres/quarts capacity, and pump the old oil out from the top via the oil extraction tube which sits in the middle of the oil filler hole. Plenty available on Fleabay and the preferred brand on this forum is Mityvac. The oil filter is also a piece of cake to change and they are quite cheap although it pays to also get a canister removal tool, again cheap on Fleabay.
I agree that 16K is probably too long between oil changes, though it a bit hard to understand why JLR would spec this, unless to garner more repair work.
JLR does spec 16K mileage intervals or annual service. Since I think it extremely unlikely any F-Type actually does 16K miles/year, the annual service is normally performed at much lower mileage.
In fact, judging from the miles reported for a number of used vehicles, a typical annual mileage might well be below 5K miles. So, no problem if owners stick to the annual schedule.
Annual schedule makes sense especially with low mileage and Winter lay-up.
In my case, I shall hit about 9.5K miles before my free oil change in Janury after 10 months on the road, so do not think any reason to be concerned.
Also, my car will be sold before the warranty expires, likely with 50K on the odometer.
It might even get replaced with an R before then!!
Our usage (especially with the Pandemic) has been only 3 - 4,000 a year.
Who know why they only tell you miles. If your car is a weekender, you won't drive that many miles before the service is due.
DC
There may not be many F Types doing 16k miles per year. But the engines are used in other JLR vehicles too. Eg we have the 3.0 V6 SC in our discovery. We run 16k between oil changes. Oil analysis came back very clean when we tested it a year back
Lots of very different views on this. I do the f type more frequently. As a low cost precaution. But in general oil performance is vastly improved on decades ago, hence the longer intervals
But I think that one factor in that longggg interval is the rather large amount of oil in the Jaguar's sump. The engine has 16,K miles to 'wear out' the additives in 7.25 qts of oil.
As a comparison, newer Honda Civics and CR-Vs with the 1.5L turbo engine have a 3.5qt capacity. Still, they can last 5,000 to 9,000 miles before the OLM (OIl Life Monitor) turns on.
Hey...Do what makes sense for you, and your situation. It is not like it is going to blow-up, or even malfunction with longer oil change intervals. It is kind of like exercising once a month, or every other day...Neither will likely die, but the every other day person is going to be much more fit, and maybe last longer Another reason for the TIME interval (and not JUST milage) is the chemical/physical properties of oil. Heating and cooling cycles make oil become acidic...As such, you do not want to leave acidic substances in the engine longer than needed...because, hey...its acid!...So replacing it with fresh oil, also reduces the acidity as well.
DC
DC
I drove only 2,200 miles last year and still changed the oil annually. And I also received a message that I was due for the service. As others have mentioned-do what is best for you. I change my oil annually if I don't reach the mileage and have done so in this and past Porsche's that were just fun weekend cars. It's cheap insurance and since I do it myself spending 30 minutes and $80 once a year is cheap.
