Set active exhaust to default on
I am a new owner of 2019 f type R, and I am assuming from what i can tell my model year uses engine vacuum, the previous owner had disconnected vacuum line to the exhaust valve and plugged them up, no wonder i could not tell the difference when i pressed the exhaust switch, now I plugged the vaccum line back in the vacuum actuators and now i can see the valve open and close. now when i start the car cold its not loud at all as the exhaust valves close 2 to 3 sec after startup and during the cold start cycle if i press the exhaust switch the valves do not open , they only open after the cold start cycle is complete, is this normal? its a bummer i dont get the loud barking noise during start up but i also want to able to control the exhaust sound. thanks
dan02xk8
07-21-2016 05:22 AM
