Short Shifter, Anyone?
Old 08-25-2018, 06:08 PM
F-Envy's Avatar
Unhingd,
Thank you for researching this. I tried to locate the OEM part numbers for the shifter to see if maybe it too changed or is the same, but had no luck. I expect to receive the car within the next 10 days and will measure the throw length from 3rd to 4th and report back. I'll also check with the parts department while I'm there for part numbers for 2016 - 2019 shifters.
  #242
Old 08-25-2018, 06:15 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
The numbers I listed in post 240 are the part numbers. At this point, if the OEM throw is still 4”, the only thing left is to do a test fit of the short-shift kit on the updated OEM shift rail.
  #243
Old 08-25-2018, 06:25 PM
F-Envy's Avatar
OK, thanks. I didn't realize the shifter was included with the rail assembly.
  #244
Old 08-26-2018, 12:10 PM
Atomic's Avatar
Jaguar replaced my entire manual transmission earlier this year - back when some of us were having our clutch assemblies replaced a few years ago, my local dealer neglected to replace several parts in mine, and this caused me to completely lose 2nd gear in early 2018. Anyway, according to my warranty invoice, I got this new shift rail as part of the complete transmission replacement - there is significantly less play in the shifter now and the feel is hugely improved...
  #245
Old 08-26-2018, 12:23 PM
Unhingd's Avatar
Please measure the throw at the top of the knob.
  #246
Old 08-26-2018, 03:00 PM
SinF's Avatar
Received 2,141 Likes on 1,461 Posts
Is there a part number?
  #247
Old 08-26-2018, 04:45 PM
Unhingd's Avatar
All the pieces come as one assembly. The part numbers for gen 1 and gen 2 listed in post 240.
  #248
Old 08-26-2018, 09:54 PM
Atomic's Avatar
can you give me some idea of how to do this? Sorry - just need some basic instructions
  #249
Old 08-27-2018, 04:06 AM
Unhingd's Avatar
I measure the distance from the bottom of the middle climate control knob to the outer edge of the metal cap on top of the shift knob. Take measurements in 3rd and 4th gears, and report the difference between the two.
  #250
Old 08-30-2018, 12:58 PM
Uncle Fishbits's Avatar
The internet is bereft of visual help on the Carbon Fiber manual gearshift. This is the only pic that exists anywhere, and it's in the options side of configurator, but I am assuming no one has bought one, because I can't find a pic anywhere.
Any of you have this thing? Could I see a pic?
  #251
Old 08-30-2018, 01:23 PM
Unhingd's Avatar
priced in the triple digits, I’m guessing?
  #252
Old 08-30-2018, 02:30 PM
ding ding ding
$120
But if it's more comfy, etc.... that's great. I am getting it because it reduces some of the weight of the car <--- joke
I added it on a whim. I like our shifter, it's comfy, but it's a bit dull. I don't need it at all, but curious what it looked like installed. Maybe I have to get it so I can get a photo of it online. For posterity. =)
  #253
Old 08-30-2018, 02:36 PM
Unhingd's Avatar
ding ding ding
$120
When did those knob first appear? I didn’t know there was such a thing until a few days ago when I was reviewing the part # updates for the shifter rail.
  #254
Old 08-31-2018, 03:41 PM
This tight boolean search with only 9 results (when does that ever happen??): https://goo.gl/cdCfa1
suggests 2018: https://images.jazelc.com/uploads/ga...m97-366026.pdf
under page 79, 1st of "key optional features"
  #255
Old 09-01-2018, 08:40 AM
Stwsam's Avatar
I installed the factory carbon fiber knob when I installed the patented Unhingd short throw. In fact Unhingd noticed the knob in the in a video and I provided him with the pn. At the time, he was assisting me on an issue
I was having with my install> The car is clearly quicker and lighter with the CF knob. Just night and day! NOT!!! But looks cool!
  #256
Old 09-01-2018, 01:56 PM
Unhingd's Avatar
Clearly my memory is fading, but I like the knob. Those ounces add up.
  #257
Old 09-01-2018, 07:27 PM
OzXFR's Avatar
Received 3,226 Likes on 2,380 Posts
Funny that, when I drove manuals (for all of the 40 years before I got my first Jag which was also my first auto) one of the first mods I did was to replace the stock shifter knob with the heaviest one I could find that fitted and looked good. I found that a heavy knob resulted in a more solid shift feel and made the shift easier and more precise.
  #258
Old 09-01-2018, 09:13 PM
Stwsam's Avatar
Tada!!
  #259
Old 09-02-2018, 09:52 AM
Unhingd's Avatar
Agreed, but on the F-Type, this is where a 0.52 kg weight is added to the shifter:
  #260
Old 09-02-2018, 06:28 PM
OzXFR's Avatar
Yep, on a couple of cars, as well as swapping out the knob for a heavier one I added extra weight around the bottom of the shifter shaft.
Nothing as fancy as that bit in the pic, instead I found a chunk of raw lead, flattened it out with a hammer, wrapped it around the shaft and tied it down with a zip tie.
Worked great and never gave me a problem.
Quick Reply: Short Shifter, Anyone?
