Short Shifter, Anyone?
#81
Quicker is likely, smoother not. The smoothness is determined by the linkage in the transmission tail assembly. The short-shifter is constructed by changing the relative pivot location of the shift arm, so smoothness will not be addressed, only speed.
#82
#83
My MINI (short) shifter is even more notchy than the F-Type, but I actually like it that way (strong indent springs)... a very positive feel with full confidence the tranny will stay in gear. I'm not a fan of smooth shift patterns. The short shifter, having less mechanical advantage, will actually accentuate the notchiness.
#85
#86
#88
On new path
After several months of empty promises from Fidanza to make progress on the short shifter project, I finally decided to terminate my involvement with them. However, a well known shifter manufacturer in the Netherlands has offered to look at the shifter rail that I will be sending them to determine if they can develop a solution. If that fails, I will work with a local machine shop to build a prototype. If they do choose to proceed, I will provide details as we make progress.
#89
It's unfortunate that Fidanza has determined that it is not commercially viable. It may be true, but it's still unfortunate. As before, I am still interested, and if the cost is within reason, given the market, I will reaffirm my previous commitment. It'd be nice to get the shifter throw of my 26 year old Miata in my new Jaguar.
#90
Please measure the throw on your Miata, and let me know what it is.
The throw on the F-Type OEM shifter is ~10mm, and it's 7.5mm on my MINI short-shifter. With the reduced mechanical advantage, getting the MINI into reverse requires a bit of a grunt, but it's OEM gate spring was stiffer than that of the F-Type out of the box.
Also, are you satisfied with the relative position of the shift knob? For typical driving, I personally would prefer it lower, but when charging into corners, I would prefer it closer to the wheel. I'm thinking it should be left where it is as a decent compromise. In any event, I'm hoping it can be made with a non-tapered shaft so that we can mount any knob we want to. The OEM tapered shaft makes it virtually impossible to find anything else that fits.
#91
#92
#93
I get a bit less that 10cm for the F, measured on the 3-4 line. The Miata is about 8.5cm measured the same. Side to side is pretty similar, because the sideways movement from the 3-4 line to 5 is pretty long on the Miata.
The centerline of the steering wheel to the shifter, sitting in neutral, is about 36cm for the F and about 35 for the Miata. Overall, not that different. I didn't measure height. I think I concur; that the position is a reasonable compromise.
#94
Are you sure those aren't cm? :/
#95
I had the entire shifter rail mechanism shipped to M-Tech in the Netherlands, and just got this message on Saturday: "Just to let you know we have received the Jaguar shifter. I will start development as soon as possible. We are a bit busy with more shifter types for other car brands, but I will try to get this Jaguar short shifter kit ready as soon as possible."
The following 2 users liked this post by Unhingd:
Inspector-G (01-24-2017),
jfranks (01-23-2017)
#96
Finally, progress.
M-Tech has designed the shifter, reducing the throw from 100mm to 72mm (28%). They will be offering the shifter (Model S645-Shift, also known as the Unhingd Shifter )online in about a month for 279 euros plus shipping from the Netherlands, but will not begin production until they have a certain number of orders. I have decided to order sufficient numbers for immediate production, which they have offered me at a discount. I will be selling them for US$275 plus shipping from Maryland, but will offer them to forum members for US$225 plus shipping from MD.
Before I ship them I will test fit one on my car in case adjustments need to be made. I can then provide complete installation instructions with pics (and time needed). It is likely that the car will need to go on a lift, but the tranny will definitely not need to be removed from the car. On Monday, I should have a better idea when they will be available. If interested, please pm me.
Inspector-G (02-18-2017)
#98
Unhingd (02-18-2017)
#99
