Side mirror issue
Having a side mirror issue, 2019 F-Type P300 passenger side mirror is loose, can’t find anything on being able to fix this and if it requires removal to fix. The mirror is slightly loose, fully intact. Does move when I try to wobble it and it is not firm like the other side. Folds in and out fine when locked and unlocked. Then I took notice when I locked the car to see what was going on. The mirror folds into the door without leaving a gap, in other words folds too far into the door causing the mirror to slightly move upwards and I’m guessing that’s what’s causing the mirror to loosen. Not sure if there’s a possible adjustment I can do? If you have any information on this I’d greatly appreciate it. Thank you all in advance.
