Side Vents with IRR accents
I would have preferred the black pack on my car but it didn't happen. I have always dechromed all my cars and the F-type is no exception. It's unfortunate the chrome around the windows is so expensive, so that won't get replaced, and I'm not a fan of wraps. However, I can live with the window trim because I do think the chrome around the windows does tie into the wheels. The side vents to me look bad in chrome, so, I bought the black version of the side vents and purchased some IRR paint from Microfinish LCC out of New Orleans. I put two coats of adhesion promoter, three coats of base IRR, and three coats of clear coat. Enjoy.
BruceTheQuail (03-25-2019)
SS4PK (03-25-2019)
No trick, no broken clips. Just remove the three 10mm bolts across the top of the fender and loosen the one 10mm bolt between the door and fender, pull the fender out a little and work the clips loose from the inside. I replaced the vents. The first one took 30 minutes and the second one took 15 minutes.
the vents don’t open into the engine bay.
Carbuff2 (03-25-2019)
abonano
07-17-2013 08:11 PM
cyan
12-27-2007 08:52 PM
