Simple Battery Reboot Mod
Well....As I have become more familiar with these cars, I have learned how touchy the battery issues are, and particularly when connected to OBDII devices/readers.
Thanks to many on this forum, I have learned that it is usually a quick and simple "Battery Reboot" fix, to clear and allow the car to go to sleep mode again. After a couple of times, I was
getting tired of disconnecting the cable etc...So came up with the solution/mod in this DIY. There are obviously all sots of alternative approaches you could do here...
I fully recognize this is nothing pervasive, or genius, but may be helpful to any that want to do it. And it is a simple mod that is somewhat useful....And something to do while on lock-down!
Hopefully some (or one) will find it useful/helpful.
DC
DC
The following 11 users liked this post by Therock88:
andykreb (06-09-2020),
cloverfield (02-19-2024),
djyankees31 (06-09-2020),
madmax1911 (06-10-2020),
Mbourne (06-09-2020),
and 6 others liked this post.
Received 3,209 Likes
Yep, great idea, I just bought one on Fleabay.
But I'm not sure why you would need to disconnect the negative battery terminal first?
Surely just unbolting the earth lead from the floor of the trunk/boot (the first part of Step 3 anyway) does the same thing?
Or do you need to disconnect the neg terminal to avoid upsetting the BMS?????
On the disconnecting the negative terminal...It is not an absolute must (I document how I do the DIYs). The suggestion to do so is more as a simple precaution for the electronics in the car. Given the many modules, sensors, and other delicate electronics, it is safer to not have the circuit complete while you are working with it. As you are fastening, and removing the cable, it would create multiple arcs and sparks as the metal intermittently makes contact....This is not good for IC's and other electronic components.
So, all that to say...It is just a precaution while you are fitting the cable back to the grounding bolt and switch. Not absolutely necessary.
DC
The following 2 users liked this post by Therock88:
madmax1911 (08-20-2020),
scm (06-10-2020)
Thanks for the post.
I'm so stupid that it took me after the 2nd annual inspection to read on here to figure out that the OBD reader completely drained the battery a few days afterwards.
Assume almost same install for convertibles...
Ques:
A few videos on install attached the negative cable to the side post on the switch itself, instead of attaching it to the floorpan bolt:
Same for instructions from the switch company:
https://www.walmart.com/ip/Heavy-Off...500-/247218933
Any advantage/disadvantage of either install?
Thanks,
Ques:
Thanks,
Ques:
https://www.youtube.com/watch?v=2nM48nUhkQk
Thanks,
Ques:
Thanks,
Good luck.
DC
Maybe a battery disconnect switch as used on racing cars? Definitely more work because of mounting, but it could be mounted in a more accessible location.
I don't connect an OBDC device often enough to care, but it's an idea.
JacksonvilleJag (06-11-2020)
Carbuff2 (06-12-2020)
Otherwise how else do you replace the battery?????
Also, you don't really need to remove the negative battery cable connection from the battery itself, you only need to undo the bolt holding the other end of that cable (the earth/ground) to the floor of the boot, see earlier posts by Therock88. Just be careful when fitting the gizmo and reconnecting the cable to avoid sparks!
On my XJR I like to leave the OBDII device plugged in all the time. I found this unit which powers down with the car and have had no battery issues yet.
I am still on the factory battery on my 2014 model.
It is a bit expensive compared to other adapters but I really like the push button to force it to pair.
I don't have a 'vert but surely that panel covering the edges of the battery can be easily removed and replaced, giving you easy access to the negative terminal?
Just another stupid cowboy not comfortable with pulling out trunk panels without suggestions from forum members.
Thanks in advance.
