Simple mods, fun mods, minor mods or updates?
Old 09-06-2018, 03:52 PM
Chawumba's Avatar
Originally Posted by eeeeek
Oddly enough, I'm having an aesthetics struggle with a car mod right now. I am looking at blacking out my badges and have even considered blacking the faces and making the raised edges red (to match my interior and brake calipers). She said both look cheap. I'm torn, as I have the black pack on my car and the chrome badges look a little out of place to me, but she has a spooky habit of being right...
You both could be right! It may indeed be too busy to go with two colors for the emblems, but I think chrome badging looks out of place on cars with the black pack. Many members here have painted their leaper and other badging black, looks great IMHO.
  #242
Old 09-06-2018, 04:42 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Originally Posted by DJS
More like...
Yep...that pretty much sums it up.
Back to being serious...Now ready to take on SPECTRE!
The following 4 users liked this post by Unhingd:
Don1954 (09-12-2018), Jaguar1611 (09-25-2018), Magical (09-06-2018), Mbourne (09-06-2018)
  #243
Old 09-07-2018, 11:31 AM
Uncle Fishbits's Avatar
Just wait til 2019MY badging hits the streets. This doc, page 5.... there's new badging it seems. Weird badging.
File Type: pdf
Dremorg (09-07-2018)
  #244
Old 09-07-2018, 12:10 PM
eeeeek's Avatar
It's the same with Range Rover. On my SO's Velar, there is a little black tag underneath Velar in the back that says P250 (signifying the 4 cylinder). The 6 has P380. Diesels start with a D instead of P. A decent write up is here:
https://www.autoblog.com/2017/09/27/...ng-convention/
  #245
Old 09-09-2018, 05:55 AM
KVO's Avatar
KVO
KVO is offline
Mats with leather matching the seats and console. Aftermarket, as Jag charges a whopping €477 for a similar finished set. These were only €47 delivered at home.
Mbourne (09-09-2018)
  #246
Old 09-09-2018, 06:06 AM
Nati's Avatar
Ooo! Where are those from?
  #247
Old 09-09-2018, 06:16 AM
KVO's Avatar
KVO
KVO is offline
Profimats, a German based company.
The following 2 users liked this post by KVO:
Mbourne (09-09-2018), SinF (09-09-2018)
  #248
Old 09-23-2018, 06:08 AM
KVO's Avatar
KVO
KVO is offline
In preparation for the winter to come, I installed a Ctek battery conditioner connection, the OEM way.
Other than the JLR ones (which is Ctek as well), this type actually shows the condition of the battery, and way cheaper - browsing the net, I found one on sale for €17 only, delivered at home.
Mbourne (09-23-2018), mp_x152 (09-25-2018)
  #249
Old 09-23-2018, 08:39 PM
ssaeed1973's Avatar
Did you have to make the cuts yourself? What model CTek did you purchase?
  #250
Old 09-24-2018, 11:49 AM
KVO's Avatar
KVO
KVO is offline
Yep, you need to cut/make the needed hole yourself. The JLR type requires a 17mm hole to be drilled.
I needed a rectangle hole, and made a little wooden template first matching the size of the Ctek box, just to make sure I was making the hole of a correct shape/size.
The trim is quite solid material, so if you were to cut, I would be careful. To get through, you'll need to apply quite some force, and then might accidentally make the cut too big...
I punched some little holes in first, then cut it out, but on purpose a bit too little to be on the safe side, and not to mess up my trunk trim.
Made the final shape by use of a metal file, until it matched my template perfect.
The one error I made - I made the hole a bit too high. There is some kind of electronic box behind the trim, and you are supposed to stay under.
I was actually lucky all did fit well after all, but the hole about an inch lower would be better.
I used this Ctek panel mount.
I did only remove the trunk's bottom trim, but kept the side panel in place - my guess you need to remove the panel if you were to use the JLR (Ctek) kit,
because of the nut needed on the back of the panel.
For reference, the JLR battery conditioner installation kit guide:
File Type: pdf
  #251
Old 09-25-2018, 06:06 PM
Jaguar1611's Avatar
Switched from the Black Start button to Ignis Orange. It really sharpens up the cabin.
I used a business card curled in a circle to pull it out. Only took a few tries.
Recommend!!
  #252
Old 09-26-2018, 01:16 PM
Magical's Avatar
Default Key fob covers
RED is made of rubber in case you drop em a lot
WHITE is made of plastic in white and chrome and comes with the belt loop hanger...more dressy. < my fav
1 less thing to carry in your pocket or vehicle...comes in diff colors
Amazon
  #253
Old 09-26-2018, 01:50 PM
Kdes's Avatar
Leather cover for me
  #254
Old 09-28-2018, 08:45 PM
Stuart S's Avatar
Received 6,285 Likes on 3,449 Posts
This will keep your passenger from becoming unruly. Don't forget to lower the top first.
Uncle Fishbits (04-19-2019)
  #255
Old 10-10-2018, 08:39 PM
Unhingd's Avatar
Posted to wrong thread
  #256
Old 04-19-2019, 01:11 PM
Okay.... I took way way too much time out of my morning looking for the fire missiles and passenger eject, and CANNOT BELIEVE I FOUND THEM.
So... I see cat buttons for start stop, but I like the pulsing Jaguar heart beat. https://www.ebay.com/p/Engine-Start-...76278721&rt=nc
I see metallic button sticker covers: https://www.aliexpress.com/item/Car-...913246607.html
and although gaudy and silly... I did find the missile and more: https://smile.amazon.com/s?k=funny+c...f=nb_sb_noss_2
this shop has both eject and missiles: https://smile.amazon.com/Kei-Project...dp/B07D538556/
And I am silly enough that I could find a way to tastefully label my buttons....
jaguny (04-20-2019)
  #257
Old 04-19-2019, 01:27 PM
Unhingd's Avatar
The following 2 users liked this post by Unhingd:
jaguny (04-20-2019), Uncle Fishbits (04-22-2019)
  #258
Old 04-26-2019, 11:22 AM
Swoody's Avatar
Originally Posted by Unhingd
Here's the back of mine without the lettering:
i want to do this also but I am worried that on a white car there may be some sort of staining left behind that I could not polish off.... anyone with white do this??? It is very busy back there with all the lettering....
  #259
Old 04-26-2019, 05:40 PM
OzXFR's Avatar
Received 3,209 Likes on 2,366 Posts
No problemo regardless of the colour including white.
Remove the glue residue with your favourite remover (I use eucalyptus oil) then polish the area with your favourite low cut polish (I use Megs Ultimate Compound), then wax. Comes out looking like new with zero trace of where the badges were.
15donoja
09-11-2016 04:45 PM
John Herbert
07-02-2016 02:41 AM
j_bond
01-10-2013 04:55 AM
Manofsteel
06-07-2011 12:29 AM
Quick Reply: Simple mods, fun mods, minor mods or updates?
