Slight thump when pressing and releasing gas pedal
As the title says, I've noticed a dull "thunk" probably half the times I press on the gas pedal. This also happens at the about the same frequency when I release it, while decelerating. I can only describe it as a feeling more than an actual sound, as if it were catching a gear, and only happens while I am driving.
Otherwise, it runs fantastically smooth, so I'm hoping that this is not too big of an issue. I'm also seeing my local JLR for an unrelated service (new brake pads) in a couple of weeks and I plan on bringing it up to the mechanic then. For reference, my F-Type R has 23300 miles on the odometer.
Cheers!
Cheers!
I assume you only feel/hear this with the engine running. If true, I suspect that something, probably part of the exhaust, is contacting the chassis as the engine rotates due to torque, producing the "thump." I suggest getting under the car and looking for contact witness marks.
