Slow WOT Kick-Down - Any Tricks?
I do a lot of highway trips and frequently merge onto the interstate and find the need to mash the throttle to get into traffic holes in the fast lane. Usually I am traveling at around 50mph when I merge (stuck behind other cars). The 50-70 time is reported by Car and Driver to be 3.0 seconds which is actually pretty slow and I must assume this is because it takes FOREVER for the tranny to kick down into the lowest gear. Does anyone, for the love of all that is holy, have any tricks to speed this up. I am always in dynamic mode, but often not in sport mode. I find that whacking the shifter over into sport, as I am starting to floor the car does not seem to speed the downshift up whatsoever. I also promise I am pushing the accelerator through the WOT button and it just seems to take so long. Anyone find a fix for this? Any Ideas?
I suspect if you used the paddles to downshift rather than the kick-down switch, it would happen more quickly.
Traction is there at 50MPH. I live in Florida and its warm and dry here. The car takes off like a rocket from 5MPH, but at 50MPH it just feels so confused and lazy.
I'm always in sport mode on the onramp.. then switch over once I'm in traffic. In traffic, I use the paddles to pass if I think it needs to downshift. I believe a BIG reason modern automatics have the stick +/- and paddles is specifically for what you are describing. Getting in the right gear for passing/merging, etc..
Really surprised at the 3s time. I've never felt that, but maybe because I don't drive the same.
I typically drive in sport and dynamic when on highway. I wonder if the car learns the passing behavior as i too have short ramp situations. I find sometimes stomping on the gas the car doesn't react, but apply gas pedal aggressively but not flooring it achieves better results, but damn, you have to be careful as other drivers may not be able to react when your car takes off like an Apollo moon shot.
