Smartphone Bluetooth connectivity with Jaguar
Old 10-29-2015, 05:13 AM
Received 4,280 Likes on 3,700 Posts
Default Smartphone Bluetooth connectivity with Jaguar
Originally Posted by sklimii
Thanks to Stuart S for great info below:
"Will my smartphone connect with the Bluetooth in my Jaguar?"[/I]
Here is THE DEFINITIVE SOURCE: Vehicles - Jaguar Click the link and you can search (1) by model and year or (2) you can enter your VIN.
If this was helpful, please press at the bottom right.
Stuart
[/QUOTE]
The following 8 users liked this post by sklimii:
Arajan (08-21-2020), CaptainDavid (02-02-2017), DJS (10-29-2015), MaximA (09-11-2016), Mbourne (10-29-2015), Prophizee (11-15-2016), Shagman82 (04-25-2022), yugwmb (02-15-2017) and 3 others liked this post. (Show less...)
Old 10-29-2015, 07:29 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
We all know the F-Type has connectivity, but I wish the range were a bit longer. The connection will cut out if you leave the phone in your shirt pocket. Phone has to be right of center of the steering wheel for the connection to be reliable. Obviously, not an issue for those of you with a bonnet & boot instead of a hood & trunk.
MaximA (09-11-2016)
Old 10-29-2015, 07:36 PM
Mbourne's Avatar
I agree the range is not great. I also use the usb to change and stream music rather than Bluetooth for music. The biggest problem I have is the audio connection does not always get picked up if I disconnect the phone to get out of the car and then get back in a few minutes later. I have to plug and unplug a couple of times to get it to recognize the device.
The following 3 users liked this post by Mbourne:
MaximA (09-11-2016), Steineronbass (08-10-2021), thechaosmachine (10-30-2015)
Old 10-30-2015, 09:01 AM
DJS's Avatar
DJS
DJS is offline
Received 2,106 Likes on 1,406 Posts
Interesting. I leave it in my left pants pocket, and have never had an issue, although I don't use it all that much via BT.
Old 10-30-2015, 11:32 AM
meefer's Avatar
I find that quite odd, mine has picked up my iPhone from my bag in the trunk before. Granted it wasn't the most reliable, but it's rock solid if the phone is in the cabin.
Old 10-30-2015, 03:37 PM
thechaosmachine's Avatar
This totally explains why I've had so much trouble streaming music on my phone. I generally leave it in my cup holder or pants pocket, and now I understand that it's the bluetooth range rather than something else. Always fine when connected, but I never put 2 & 2 together.
I got the Scosche mount recommended in another thread, and will see if that helps.
Thanks for helping me connect the dots.
TCM
Old 10-30-2015, 08:16 PM
Unhingd's Avatar
Mine works fine in the center console or tossed on the passenger seat, but real spotty when it's in my shirt pocket.
Old 10-31-2015, 07:38 AM
DJS's Avatar
DJS
DJS is offline
Must be your aluminum foil shirts. Seriously, that sounds odd.
Lookout! (11-28-2015)
Old 11-06-2015, 05:33 PM
TXJagR's Avatar
On a serious note... You mention aluminum... I wonder if there is ANY issue with the "looks like carbon fiber" aluminum trim all over the dash...
Where exactly is the bluetooth receiver in the F-Type?
Old 11-28-2015, 06:06 AM
Lookout!'s Avatar
I use an iPhone 6 and have had zero issue with strength of connection. My only complaint is that it seems it should connect quicker upon starting...but I'm complaining about a 30 second delay
Old 01-12-2016, 03:16 PM
Geoffg1234's Avatar
Default Canadian version
[/QUOTE]
I have a 2016 ftype r and can't get a simple answer from Jaguar or my dealership re apple carplay or remote start. Can anyone answer: Does apple carplay work with Jag in Canada and does the remote start app work in canada. My car has the hardware for incontrol apps. Thanks
Old 01-12-2016, 05:25 PM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
Apple Carplay™ doesn't work with any Jag anywhere. Hopefully someday they will see the light, and I see the new '16 Chevy Malibu (starting at $22K) has it.
I can't answer your remote start question for Canada.
Old 01-12-2016, 06:27 PM
Geoffg1234's Avatar
Default Difficult to understand
Thanks for the info. Hard to understand why Everyone from GM to Ferrari have it and we don't. Seems like such a simple thing to add.
Old 01-12-2016, 07:06 PM
Foosh's Avatar
I agree.
Old 05-29-2016, 03:58 AM
Steve Youn's Avatar
In my 2014 V8S, my iPhone pairs perfectly, but I can't stream music if my iPod is also connected to the USB. Overall I'm really disappointed with the infotainment system. It's definitely worse than my last three cars ('13 Mercedes, '11 Audi, '08 BMW). Kind of sad that a 2008 vintage tech system had better features and connectivity given the pace of advancement in smartphones, etc. I am liking my Jag a lot (especially with the top down), but the driver experience falls down when it comes to the Nav / Audio / Interface. The lack of a physical wheel or pad to quickly navigate menus or lists is a huge part of the problem. All of the German makes have this figured out.
Old 05-29-2016, 07:59 AM
mikelanzetta's Avatar
I have the same car, and agree. The level of tech of the Infotainment screen is lacking. However, if you mount your iPhone on the dash, the experience is complete. I use Waze for my nav (NEVER leave home without it!), and play my own playlist or Pandora thru the USB. I have access to everything on my phone, and it charges while I drive. I have everything I need at my fingertips.
Old 05-29-2016, 02:16 PM
Unhingd's Avatar
+1.
Burt Gummer (07-22-2016)
Old 06-20-2016, 09:30 PM
amr42's Avatar
I have noticed that the blind spot monitoring indication in the mirrors can interfere with BT audio streaming. Anyone else noticed this behavior? Would be good to know where the best place to locate cell phone is for consistent BT connection behavior...
Old 06-21-2016, 08:31 AM
Unhingd's Avatar
The BT device needs to be to the right (left for right hand steering) of the center of the steering wheel. Spotty if in the left shirt/jacket pocket, never any problem in a right jacket pocket.
Old 06-21-2016, 02:43 PM
Dogbreath!'s Avatar
I put my phone in the cup holder. Never a problem with BT.
Quick Reply: Smartphone Bluetooth connectivity with Jaguar
