Snow tires and wheels. Winter tires on dedicated rims for the F-Type. Recommendations
Old 07-01-2019, 04:00 PM
Luc Lapierre's Avatar
Bump
Old 07-01-2019, 06:57 PM
I have another question!
What's the maximum diameter we can run without any rubbing?
My stock v6s setup is 27", it looks like OP's winter setup is 27.7".
Old 07-01-2019, 07:09 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
At least 1.5” more than OEM with no lowering or spacers.
Luc Lapierre (07-01-2019)
Old 07-09-2019, 06:59 PM
Josue Ferreira's Avatar
Originally Posted by dirk_BE
I just bought a set of OEM 18 inch rims to decicate for winter tyres. In summer I run 20 inch.
Do these clear the 380 tho?
Old 07-09-2019, 07:20 PM
OzXFR's Avatar
Received 3,259 Likes on 2,405 Posts
No.
As stated elsewhere there is no such thing as an OEM Jaguar 18" wheel which will clear the 380 mm front brake calipers. Not F-Type, not XF, not XK, not any Jag wheel.
It is possible that an after-market 18" wheel exists that clears the 380 mm calipers but I've never read or heard of one and it would very likely have to be a custom made wheel at any rate.
Old 07-09-2019, 08:38 PM
Forrest Keith's Avatar
No. Sorry.
Old 10-29-2019, 09:10 PM
Joedon62's Avatar
Originally Posted by Nati
Blizzak LM-32s on Coventry ashfords that I had refinished to a dark gray. Stock size and offsets so no need to futz with hub adapters or spacers. I even pop in the growler center caps from the stock wheels when I swap them.
Hi Nati,
Were your ashfords the silver mirror before you refinished them?
Thanks...
  #28
Old 11-05-2019, 07:03 PM
Nati's Avatar
Originally Posted by Joedon62
Hi Nati,
Thanks...
They were black barrels with a mirror polished face. It was waaaaay too much chrome.
Old 11-05-2019, 07:08 PM
Joedon62's Avatar
Thank you. I agree way too much chrome..
  #30
Old 11-16-2019, 03:52 PM
EJag66's Avatar
I actually just put on a set of Bridgestone P980AS, stock sizes, and I really like them. They provide a smooter ride than the PZeros and less tire noise. No notable loss of handling either.
  #31
Old 06-06-2022, 09:34 PM
dBel84's Avatar
Hello all , sorry to revive an old thread but @Forrest Keith experience seemed to mimic what I am starting to appreciate. I am a new ( 6 weeks in ) owner of a low mileage 400 Sport ( 2018) convertible and living in Wisconsin has made me think of things like being prepared for snow in plenty of time. So while I am enjoying the summer drives, I am starting to navigate the ordeal of finding rims etc that will fit and allow me to continue to drive through the winter. There is not much that I could find specific to the 2018 but it seems to have similar brake caliper etc to the OPs 2016 R , hence me adding to this thread.
If anyone has first hand experience with the 400 or knows what rims will fit - I am looking to go with 4 wheels with the same 245/45/19 tire and get wheel spacers for the rears as described. Any help would be much appreciated, this is all very new to me having driven a mini cooper for the past decade and not having to think beyond something that could be ordered off the rack.
thx
  #32
Old 06-06-2022, 10:34 PM
OzXFR's Avatar
thx
Yep, the 400 Sport came stock with the same brakes as the R so 380 mm front and 376 mm rear.
As I said before no OEM Jag 18" wheel will fit over the front 380 mm brake calipers but all OEM F-Type 19" and 20" wheels will fit.
Unless of course you have the CCM brakes (doesn't sound like you do) in which case only two types of OEM 20" F-Type wheels will fit, Maelstrom and Storm.
  #33
Old 06-06-2022, 10:42 PM
dBel84's Avatar
thanks , am looking at 19" as the ideal. Any idea whether 19" F-Pace OEMs will fit - more of them seem to be out in the wild.
  #34
Old 06-06-2022, 11:06 PM
OzXFR's Avatar
Dunno, maybe yes maybe no. I believe the F-Pace has different brakes to the F-Type so it's possible that F-Pace 19" wheels which fit over F-Pace front brake calipers do not fit over F-Type 380 mm calipers.
There is also the question of possibly quite different wheel offsets, the fronts should be the same or near enough but the rears could be very different, I know XK and XF rear wheel offsets are nothing like F-Type offsets.
At least they have the same bolt pattern, PCD and centre bore so caliper clearance and offsets are all you need to find out about.
  #35
Old 11-20-2022, 05:06 PM
dBel84's Avatar
My first winter is fast approaching ( actually snuck on me while I was enjoying the last rays of summer ) BUT I was prepared
Fitted the winter wheels this weekend as I didn't have time before there was snow on the ground - they fit perfectly and am looking forward to driving year round.
Summer fun
Front Pirelli 255/35/20 Rim : 9Jx20 ET55
Rear Pirelli 295/30/20 Rim : 10.5Jx20 ET38
Winter:
Satin Black Motegi MR153 19" ( +42 offset )
Rear wheels needed 1.25" hub centric adapter
Had been looking at Nokian Hakkapeliitta but got a killer deal on a set of Pirelli WINTER SOTTOZERO
erikasius22
05-12-2024 11:52 PM
Tman003
12-09-2018 12:35 PM
DpezXK8
01-13-2015 05:44 PM
dmpsqrd
05-25-2013 12:39 PM
Quick Reply: Snow tires and wheels. Winter tires on dedicated rims for the F-Type. Recommendations
