Software Enhancements letter received
There are TSB or Campaigns that aren't really a recall. Software enhancements could be things like the service required indication not being accurate - that seems to be a common one. Typically dealers take care of those during routine service visits but maybe they haven't seen you for a while. It's not compulsory....
I got the letter yesterday. I suspect it is a proactive attempt to get all the TSBs installed into as many vehicles as possible all at once (more efficient to do all the TSBs at once). This might include the service cycle light issue, O2 sensor programming, Meridian fix, fuel canister hose, etc.
I got the same letter on my '16 Range Rover Sport, but you're right, they did quite a few "enhancements" when I took it in for routine service a couple of months ago.
Also, in December I took the Jag in for it's yearly service and they said they needed to do the canister hose TSB, or is it a recall? They didn't have the parts so they said they will call me when they're available, nothing yet. Is this vital? Should I give them a call?
Uk2usa (02-22-2017)
The only hardware one for me was the canister hose which the dealer had in stock. I had to have the firmware updated in my telematics and audio modules in order for JustDrive to launch as I have an early 2016 model which just missed the update in the factory. They also aligned the hood with the fender better per another TSB. I don't think there's anything Danger Will Robinson there, Jaguar just seem to be proactive in improving the driver experience.
Fortunately there is no TSB for "customer reports insufficient grin when using gas pedal..."
I have an May 2016 production car for the 2017 model year. Wondering if I'll get such a notice letter.
![Thumbs down](https://www.jaguarforums.com/forum/images/icons/icon13.gif)
Just had my MY16 F-Type S Coupe at the dealer for first ever inspection/service a year after buying it. They said there are two TSB to be done, one for the stereo and the other for the head-unit or nav, I'm not sure anymore...
Anyway, I have the 380-Watts Meridian stereo in it which isn't bad, but also not really satisfying either. The update makes the system sound probably a bit improved, no enlightenment...
Concerning SatNav I've first only noticed the arrows and route line display on the map isn't bright green anymore but dark blue. Not the smartest change. But then after a while I noticed the rest of the system really get's sluggish, mostly when navigation is active... touch presses in the interface take around 1 to 2 seconds until something happens. Voice guidance is muting music for around 3 seconds until the actual announcements is heard and if multiple guidances are played they get cut off! Sometimes the music muting doesn't stop and return to full music, but hangs and the volume knob is stuck at regulating navigation volume! Additionally the cluster display stays blank on the horizontal line, no music info and no navi info anymore. I need to shut down the car for a couple of minutes to remedy the situation...
This is not acceptable at all and I'm calling the dealer today!
Has anybody else once experienced such behaviour from the on-board entertainment system?
Lyndon
Lyndon
I'm interested in the software update that will make the car a better car.
Can anyone describe what the software update does (more specifically)?
Ah if only...
818 (03-30-2017)
They inadvertently installed the 007 ejector seat explosives in a number of production units.
