Some bluetooth OBD2 Drains Battery - help find the fix!
The following 2 users liked this post by Unhingd:
Misujerr (01-24-2018),
ScubaAddict (01-23-2018)
But I shut the app down and remove the elm327 from the OBD2 port when not in use.
#28
RESULTS of BLUETOOTH ADAPTER TESTING
WHAT IS KNOWN: Red Triangle Light on center console: (car is off)
1. Will turn off after 3 minutes of locking doors. (i.e. it is best to lock doors after each test to make for the quickest results)
2. Will turn off after 15 minutes leaving doors unlocked.
3. Will not turn off at all if you are in 'battery drain mode'.
4. If in battery drain mode, you can only stop the process by disconnecting the battery for a couple seconds.
5. Disconnecting battery causes a loss of date and time settings. It did not clear any other settings that I could find - radio stations, bluetooth devices, etc all seemed intact after multiple disconnects of battery.
TESTS: Consisted of me doing multiple tests, followed by closing and locking the doors, waiting 3 minutes for the light to go off (Much of the issues found are below). I did about 30-40 different tests to make my conclusions.
BLUETOOTH DEVICE: Green in picture. Notes:
1. This is only for Android and Windows and connects using bluetooth. (No IOS)
2. This is a higher end OBD module that uses a faster and more advanced chipset then the generic OBD scanners.
3. This does have a sleep mode (no effect on battery drain issue)
4. This DOES cause the battery drain issue.
NEW THEORY: Do WIFI (non-bluetooth) connected OBD devices connecting to Apple ipod or iphone cause the same problem?
TESTS DONE SHOW THE FOLLOWING (using green OBD device in picture):
1. Once in battery drain mode, attaching a OBD device known not to cause the draining issue will not "flip the switch" back. Wired VSwitch (Tuning module) was used after the Green OBD scanner had initiated the battery drain mode.
2. Connecting the Green OBD scanner, turning on the car and setting the scanner in "bluetooth pairing" mode did not cause the car to go into drain mode. You can start the car several times, and battery drain mode doesn't start. As soon as the Android phone or Windows laptop CONNECTED TO THE OBD DEVICE USING BLUETOOTH, the battery drain mode was started. This was concluded after several tests checking every step of the way.
3. Turning off the App OR Exiting the App AND/OR turning off bluetooth prior to turning off the car made no difference. Once bluetooth connected, the battery drain mode started, and no way was found to stop it.
4. Multiple apps were tested including Torque Pro, OBDwiz and Track Addict on Android and OBDwiz on Windows 10.
5. Left OBD in, disconnected/reconnected battery and could start the car, put into pairing mode, stop the car, remove the OBD device or leave it in. The battery drain would not start until Bluetooth was actually connect to phone or laptop.
6. I may have forgotten one or two tests, go ahead and ask any questions if you got them.
INTERESTING NOTE
1. The only way I got the light to turn off after battery drain was initiated was to disconnect the battery OR start the car using the phone app. Once the doors were opened or car stopped with the phone app, however, the light returned.
New theory - would WIRELESS (Wifi) devices work? Does anyone have a wifi (instead of bluetooth) OBD device?
Does anyone use their IOS device to connect to the OBD (bluetooth or wireless). Does it cause the problem or not?
INTERESTING NOTE
4x4uk (01-26-2018)
#30
Did starting the car normally with the key "fix" the car and get it out of battery drain mode??
There's literally no reason for iOS/vs android or wifi/bluetooth or wired/not wired to have any relevance to any of this. Creating giant collages of images does not add anything to the significance of anecdotal evidence.
What you are in search of is a product that does not trigger the problem that exists with some of our F-types.
I can tell you that Autel Maxidiag Elite does not cause any problem on my car. Can't speak for other people's cars though. It might cause the problem on other's cars.
It's a good tool with thorough coverage of all systems in nearly all cars. All of the above tools only do the government mandated engine/emissions stuff called "powertrain"... very limited capabilities.
Kind of wish I was selling them back when the margins weren't so thin in this space, but I never have and still don't.
Giant photo and amazon link to follow with the motif:
#31
https://www.amazon.com/Autel-MD802-M.../dp/B0090B7M2O
Turning on the car with the key does not turn the light off.
IOS vs android and bluetooth vs wifi was just a theory. No worries - no more images coming from me!
Probably correct about different cars may have problem with different products. Nobody was delving into the issue, and I though a little research might help find something people could buy with confidence. Didn't work they way I had hoped.
I appreciate those who contributed their info to my cause, and I apologize for the large images.
Take care.
#32
Battery draw after OBDII or Allstate Milewise Device connection
I concur with all others who have reported dead batteries after attaching/removing an OBDII. However now my recently subscribed Allstate Milewise insurance program device which tracks my mileage via the OBD port is triggering the same parasitic draw from the battery causing a dead battery if not driven at least every other day. I suspicion a software problem and or the Intelligent Power System Management [IPSM] of my 2016 F-Type R is not functioning properly. I purchased but haven't installed yet an Antigravity H*/Group-49 Lithium 80 AH Battery which has its own Drain Proof battery management system. I now have an appointment 2/26/22 with the Jaguar Dealer who is going to help in the troubleshooting starting with a software update check and then a draw test, etc. Hoping to get to the root of the problem.....Later. BTW I have also installed a quick disconnect on the negative ground cable.
#33
#34
#35
Did some analysis of amp draw, with & without Allstate Milewise or Blue Drive device installed and got the following results...Car status with & without device attached
Have appointment with Jag dealer to determine if software will cure or ????. Perhaps pulling fuses in latched condition will narrow down what is causing the battery drain......
- No device installed, no module latched, car off and unlocked, Hazard light went off indefinitely=0.03 amp draw.
- Inserted device with ignition off, unlocked, Hazard light turned off, after 15 min.=0.04 amp
- With device still installed, started engine and after stopping and not locking the car, the hazard light stayed on indefinitely=2.4 amp
- Started the engine, removed the device, stopped the engine, the hazard light stayed on indefinitely=2.4 amp
- Drove car and after shut down, the hazard light stayed on indefinitely, no device attached=2.4 amp
- To avoid battery drain, disconnected and reconnected battery at negative ground, the hazard light turned off indefinitely,no device attached=0.03 amp
#38
Perhaps my drain explanations aren't clear.....Have you done any testing?
#39
#40
If the Intelligent Power System Management [IPSM] of my 2016 F-Type R were functioning properly I would think it would protect my battery from draining after the parasitic load is latched by using these OBD devices? If so I wouldn't need the expensive Anti Gravity Battery I just installed because my Jaguar branded battery drained down twice.
I am wondering after reading in the F-Type repair manual
"the system will be set in transit mode on delivery. Transit mode has no Quiescent current control module [QCCM] operation and the relays remain closed. Therefore battery drain could occur and system will not react to it. A PDI [delivery?] process requires the system to be put into Normal mode, which enables the quiescent current control module [QCCM], before handing over to the customer."
if my [IPSM] is disabled because my car wasn't put thru the PDI process properly and put into Normal mode???
