Some interior microlamps stay on even 14 hours after I locked the car!?!?
Does any one know why this lights do not go to sleep after I lock the car?
I tried by remote key, or by keyless lock but they keep staying on. (!?!?)
This happened after I made a read diagnose at the dealership. But I understood this hours after they closed, in the weekend they are closed. I feel nervous leaving the car in the garage all night with these on.
Is there any similar experience? Did I touch or do something wrong?
I left the remote key far from the car to test if these interior microlamps go or stay on as I get near the vehicle... no result.
The dealer (by tel) said no reason to worry, but I kinda do not trust them so much - they said the sleep mode may need some hours, which I find weird, But I checked at the garage and it has been a day now and the lights are still on with a locked car.
Is there any similar experience? Did I touch or do something wrong.
Does this harm the battery?
Well known issue. On some cars the Battery Control Module goes wonky after the OBD port has been plugged into. If you don't want a dead battery, you have the reboot the module by disconnecting the battery for 10-30 seconds. Mine did that consistently after an OBD read until a recent update ("Enhancement Letter updates") was applied. https://www.jaguarforums.com/forum/f...ht=enhancement
Now is after 01 o'clock in my area and I have to fix then tomorrow, as you advice!
So the challenge now will be to have the dealer or anyone use the OBD fewest times possible...
By disconnecting the battery I hope there is no damage to other things (I haven't yet memorized any seat or mirrors so I hope no collateral issues will occur)
Up to now - this Forum is far more useful and prompt for solutions then any dealer! :-)
The master mechanic at my dealer advised that Jaguar mechanics should be using a certain setting on their equipment when they finish up any work that involves plugging into said port.. he said it resets the 'module'. He also said he realized that some mechanics are not doing this and leading to battery problems.
This was awhile ago and I believe a more robust fix might be available as er unhinged post.
Lawrence
FYI: If the dealer uses the OBD port, the issue doesn't happen.
Only if the dealer uses the proper procedure and disconnects the battery while using an external power source during the OBD tap. I had to teach my service department. However, the update has resolved the problem for me and I don't pay attention anymore.
JagAlb, you will get a low battery warning tomorrow morning, but should have plenty of juice to fire it up. Just don't wait another day to reset it.
Always remove the negative (black) post first. If you attempt to remove the positive post first and your tool touches any metal part of the car this will create a direct electrical short.
Indeed, the safe way to disconnect a battery. Thanks, for reminding me.
OK Mikey, thnx! I think I had no issues this time disconnecting it (removing the red for +30 sec) and all came back fine. All interior lamps shut off now and all works OK. I will be careful to do it the safest way next time.
I made some km today and a short tour to the co-owner, my wife, that agreed with me that this F Type deserves the hours/time that we will dedicate... :-)
Meanwhile sharing first tests footage from the DDPai M6 Plus dash-cam. I am still searching how to post/share videos with the sports data display - which can be seen when playback in the smartphone screen. Busy days :-)
