Spacer f-type v6s split 20" AWD??
Hello guys!
I havent find anything that answer my question.
As the subtitle, i got 2016 v6s AWD 20" splitīs.
Does any one know what the maximum mm is for this setup regarding spacers.
When i look at it, it seams to be impossible to ad anything without **** with the fenders??
Se pic
Se pic
For those trying to help and haven't seen the car (or don't remember), there are photos here:
https://www.jaguarforums.com/forum/f...sweden-224644/
Received 3,209 Likes
Not certain what split means. A few questions. What size tires do you have (295 or 305)? Do you have original equipment wheels on the car? Looking at your picture, if you hit a sufficiently large pothole, you will deform your fender whether you lower the suspension or not.
its likely to be spiltrim in appearance. The photos show wheels with the fake wheel bolts used to simulate the split rim wheels normally used on track competition. Real split rim Wheels are made of 2 or 3 separate components, a center barrel and side/rim bolted/screwed together. By replacing the centre barrel with a wider or narrower one one its possible to vary the width of the wheel or fit very wide tyres by assembly rather than forcing over the rim
http://www.kerbappeal-alloyrefurb.co...to-repair-them
Kev
Kev
I have bought four parts now anyway, it seems to be the story with f-type, there is not so much info. So I will try.
Same story when I bought the diffuser for sports design, same when I bought the taillights from V8, but you nailed it when you thought the V8 & V6 were the same, - You were right.
So I will try. It will be the same when I try to mount the steering wheel that I just order, still i will make e tthread
Thanks for the commitment guys!
If you have OEM wheels, 295 tires and 15mm spacers you can lower the car as much as you want without rubbing tires. My original comment was based on the photo. 17mm spacers would be questionable and 305 tires will grab the fenders with 15mm spacers.
I understand but on the photo os stock wheels Tornado n 295. I feel like you, it looks like 15 mm won't fit....
My wheels/tire combo has effectively pushed the face of the tire out 15mm beyond the OEM setup. Under sharp cornering and when hitting deep potholes, the wheel is able to hinge up into the wheel well without rubbing even though my rear suspension has been lowered 1.5" (H&Rs).
But to summarise, with every OEM F-Type wheel other than Blades, when fitting 15 mm or thinner spacers/adaptors, you need to cut the ends off the studs otherwise they foul on the backs of the wheels because the recesses/hole/voids between the lug holes are not deep enough.
Some have cut the lugs, some have ground them down, others have drilled/ground the recesses a bit deeper, whatever is easiest for you.
The lugs have some 5 mm of "blank" on the end before the thread starts so no problem cutting a bit off.
DerekShiekhi
12-19-2015 12:24 AM
