Splash Guards for F type
Looking all over the internet trying to find splash guards (pick up trucks call them mud guards!) for my '21 F type R. There's a number of Jaguar car dealers that advertise parts, but I can't understand and navigate thru their web site. Tried some other reputable parts suppliers, but most don't deal with Jaguar parts and the few that did, had no splash guards available. I know I tried to get them from the Jag dealer when I bought the car new (2 years ago), but they checked and said none were available from Jaguar. I'm still chasing my tail on this one, can anyone solve this ridiculous mystery? Thanks!!
Some of us added front splash guards to match the splash guards that come stock on the back. Details are in the thread below. I am not certain if there is a difference between the '21 and the older models as far as splash guards are concerned.
https://www.jaguarforums.com/forum/f...guards-231957/
I added the XXR ones, but I now see these too:
https://www.velozdesigns.com/product...spl-black-mill
OzXFR (01-24-2023)
![](https://cdn.carbuzz.com/gallery-images/2021-jaguar-f-type-r-coupe-taillight-carbuzz-797848-1600.jpg)
![](https://cdn.carbuzz.com/gallery-images/2021-jaguar-f-type-r-coupe-rear-wheel-carbuzz-797884-1600.jpg)
![](https://cdn.carbuzz.com/gallery-images/2021-jaguar-f-type-r-coupe-taillights-carbuzz-797879-1600.jpg)
While small, it does keep some of the spray off the rear of the car. This thread is about putting something similar on the rear edge of the front wheel wells.
If you look at the link in my earlier reply you can see plenty of pictures of the "splash guards" that we added to the front. They match the ones on the rear perfectly. Definitely not splash guards in the traditional sense though. The parts we installed are officially listed as "quarter edge trim".
Received 3,209 Likes
You could be right., I'll have to peel the car cover off the back end and check it out...I did it by feel under the car cover prior to answering your post and couldn't feel anything. Regardless, having mini splash guards as these look in your pictures, that's not what I am looking for. I live in the NE USA, and during the harsh winter months, the roads are quite often laced with salt crystals (junks) and anti skid (small rocks/stones/slag , BB sized). These tend to stay on the roads well after the snow and ice are gone and usually are present through June. From July on, your OK again until December (unless the highway department decides to tar and chip roads) and the story then repeats itself. Cars like the Jaguar with big, wide, softer tires (for performance, of course!) that extend even small amounts past the wheel wells will throw this debris up on the side of the car and where it gets most vicious is the front tires, where the debris gets thrown up along the side of the car and attacks the area just in front of the rear wheel wells. It's like buck shot hammering that area and the paint get's beaten up quite badly. Most commonly you see it on Corvettes probably because there's so many of them on the road and you can easily see the damage. The solution is a true set of splash guards...not necessarily "mud flaps", but guards that stick out maybe 1". They really work and prevent damage about 90-95% of the time. The rear wheels need them as well, but the front wheels really creates more damage to your paint job. It's totally ridiculous that Jaguar doesn't have them for the F model in their Parts bin, IMO!
I am also interested in these but I would like someone else to be the guinea pig before I buy!
One reason for that is the installation instructions pdf won't load for me so I am not sure exactly how they are meant to be fitted (they say some 3M double sided tape and one screw) but I would like to know more about that screw.
Go back to post #4 and check out the linked Veloz Designs splash guards, they might be exactly what you are looking for.
OzXFR (01-24-2023)
Have you considered having paint protection film (PPF) installed either with or without splash guards for extra protection from salt, anti skid material, stone chips, etc? There are lots of posts on the forum about PPF. A popular choice on the forum is Xpel Ultimate Plus.
Photo show my answer to problem. Car wrapped with Expel, but road detritus abrading that as well, particularly on rocker panels side skirts and rear fender. Installing small plastic rear fender lips more aesthetic but not really effective. Flaps are not touching bodywork, modified and formed rallyart mud flaps fitted to rear portion of inner fender liner. Held in place by present Phillips head machine screw and added aviation type slip on nut plate installed on fender liner adjacent to but not touching metal fender lip. Two layers of expel applied to edge of metal fender lip to protect against sand etc getting between fender and flap. Easy to remove if nessesary. Mud flap formed to desired contour on sheet metal brake. My car is black so the flaps don’t stand out. Cured abrasion problem and keeps side skirts much cleaner. Can tour and rip through back roads with less chance of damage.
They look pretty neat, SJ, did you buy something pre-made or did you just buy a flap that could be cut and trimmed to your desecration? Are the bolted in place, or did you use some type of adhesive or tape, or even both? And it looks like you didn't do anything for the rear tires, or did you? Are you finding that these front flaps are all but eliminating the hateful blasting the side skirts and sides of the car get in the absence of any splash guards?
Bought rally art flaps as stated. Cut inner edge profile to my specs. The large Phillips head machine screw is part of the cars normal equipment that secures the aft portion of the fender liner. Used that as primary support for flap. As stated used an aviation type nut plate clip slipped onto the fender liner where I chose to attach the upper part of the mud flap. Drilled a small hole in the fender liner so a small machine screw positioned near the top of the flap could screw into the nut plate now secured to the fender liner. Mud flap was contoured to the profile of the aft portion of the inner fender liner ( it’s not flat). I used a sheet metal brake to create the Ben’s but you could use two 2X4s, a clamp and a little muscle to achieve the same thing.
On the other hand, I've been unsuccessfully blistering my fingertips trying to find 'rally art' mud flaps using internet access and an old keyboard.
I've found "Ralliart" flaps, but they're only made for a particular model of Mitsubishi Colts.
I've also found the "Rally Armor" website, which makes mud flaps specific for many different vehicles. But, sadly, not an F-Type. They do, however, make various implementation of "Universal" flaps - including some done with less expensive (and more rigid) poly-blend as well as with a thicker, more flexible (and more expensive) urethane.
So, please, could you be more specific in what basic product you started with, a/w/a perhaps a source? Are yours Rally Armor, or something else? Many thanks!!
HermanWiegman (09-29-2023)
My error, maybe it was rally armor, it’s been a few years and I looked at the flaps to see if there were any markings left on them ( I mounted the flap so the brand name was on the tire side) but it was long obscured. I picked these in particular as they would hold their shape after they were “folded” into the contour I wanted.
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/a2bb9eea_751c_4e99_bc01_ee5b61d4ce8b_7031dfe0f63e308d264353025d7d770cd96d8112.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/58818355_2a40_4be0_84f0_3db6854e5a0a_8bb21368b9fe5d8d039244e3781218c638af231d.jpeg)
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/02ac6d40_4ab0_4b57_9b6f_32332878554d_17e2b68a347fb3141a0f30c15996106d37e64514.jpeg)
Here are some more photos-one shows the wheel well view, the large screw at the bottom is original, the small upper screw was added by me and connects to the plastic fender liner via the aviation nut plate clip ( also pictured). The tape measure shows how low the lower edge of the mud flap can be, any lower and yo may have problems with speed bumps. At least the flap is flexible. You can see how the flap was formed to fit flush against the back of the wheel well. I trimmed the flap so it would not only protect the body work but also the steel braces mounted just behind the front wheels- it works great for that too!
Simon1967
08-11-2021 09:03 AM
