Sport seat
Sport seat
Hi guys i would like to know your idea about the piping of my 2016 r seat,it starting to flake off and cracking i just think it will get worst over time it look white underneath....i just have 27000 km should i show the dealer about it ..is it covered by warranty or they will tell me it normsl wear ?thx here pics
+1. You’ll notice it is wearing at the belt line. You might check your belts to see if one might be particularly abrasive.
I would show it to your dealer. They might take care of it. Be careful though: touch ups like this can be invisible if done by someone who knows what they are doing. But they can make it worse if they don't know what they are doing. Care must be taken about the contrasting thread as well.
Wear is very variable with coated leather. For instance, the black leather that Jaguar uses in the F-Type is much softer than the Camel I have in mine. Feels better to the touch, but will wear much faster.
These are examples of what I used to do:
The following 4 users liked this post by Paul champagne:
Abrasion is one of the most destructive elements for wear of automotive leather and it is found primarily on the bolster of the driver's seat because owners tend to slide across that part as they get in, creating a wearing of the coloured surface . This can be entirely avoided by careful entry!
The OP's question is answered simply: yes, it is normal wear because that seam is somewhat raised and thus constantly subject to abrasion from clothing -and the rougher the cloth, the faster it happens.
Abrasion damage can be mitigated by keeping the surface of the leather soft and pliable with regular conditioning. The damage shown is very easy repaired by applying (sparingly) the water-based polymer colourants produced by various suppliers: Color Plus, Leatherique, and others ( this is the same type of colourant originally applied to the leather). It takes about three minutes to do it -and because the colour is black -.probably termed "Warm Charcoal", there is no matching issue. I have done it many times on many Jaguars.
Carbuff2 (09-03-2018)
Like Sov211,
I have repaired many abrasion areas in my various cars including 3 jaguars many times. And on my two "warm charcoal" aka black, I have used shoe polish in a sponge top dispenser and then rubbed it in so there are no clear lines where it was used. Very quick and easy. But I do think you should have your dealer have an expert fix it under warranty.
Paul is correct about the color coating. I had a mobile company that does work for dealers fix my MB for similar scenarios including cracking and fading including the steering wheel. They simply sanded the area with a fine sandpaper and sprayed on the matching color.
Maybe I was lucky, but it worked throughout the entire interior.
Paul champagne (09-04-2018)
The following 2 users liked this post by Unhingd:
Magical (09-04-2018),
The information about the leather and how to repair it, remain the same though. If the dealer doesn't want to take care of it, I can give you pointers if you need it.
That said, the bolster wear can easily be repaired using the leather colourants (or similar) that I have mentioned earlier. Shoe polish as a repair for wear of the black (Warm Charcoal) colour does not seem to me to be the best idea. After polishing my black shoes I can get quite a bit of black transfer on a cloth!
Same Problem
@Stefan: I had the same problem on my '17 [black] Performance Seats with only 5K miles, less than 1 year old. Was happening in the same place along those seams in the middle of the bottom seat cushions (driver more noticeable than passenger for obvious reason). I usually wear cotton Kaki pants, and am very easy on my cars. Jaguar authorized replacement cover installed under warranty. They only replaced the driver side because the passenger side was barely visible, even though it could be seen. Troubling part is that I could have counted the number of times anybody had ever sat in the passenger seat. Everyone should take a look while under warranty. Good luck!
