Sport seats are different - is it 2017 or black pack?
Hoping that others with the sport seats (read: the base model seats) with and without the black pack can comment.
I'm almost certain that when I test drove (over 6 months ago), the sport seats had a smooth texture to the leather (basically just like the steering wheel). I just realized today, while driving around in my recently acquired car, that my seats have an obviously textured leather. The leather and the suede filler is also black, not gray as I remember.
I'm wondering if these changes are because I ordered the black pack (which I thought only changed exterior pieces and some trim on the console), or if they are 2017 changes, or perhaps both.
I thought it was weird that the texture of the leather would change.
the V6 gets a lower quality leather than the V8, evident on the dash as well
v6 gets taurus leather
v8 gets windsor leather
i'm going order process on an f-pace atm, and although hard to find the information, the first edition get's the same leather quality as the v8 f-type , otherwise it's the lower grade like they put in the XE which has a grainy plasticy feel
I can't speak to the sport seats, but they do use different leathers on the optional performance seats vs. the performance seats in the R.
Before upgrading to a '16 R, I had a 2015 Base with the optional performance seats. The leather on those seats was lighter in shade (black) and much more stiff than the leather in the R. Much of the trim in the Base was plastic / vinyl and had pieces that might have been leather, but looked a lot like vinyl.
Contrast that to the R where everything is a soft grained leather. Rightfully so though, because you are paying a premium.
My Jeep Grand Cherokee is the same way. They have 3 different types of leather; improving in quality as you go up in models.
Do you have the sport or performance seats?
You probably know this but when they get a hide they soak it and then split it into a number of sheets.. The top is where the follicles are and it breathes, so that is top grain or analine. The underside is suede. Then everything else is corrected grain, with a grain printed on in paint.
You can sometimes tell by stretching the leather - if the grain disappears it is probably real, if it stays it is probably just a shape in the paint over one of the under layers in the hide.
I have what looks to be semi analine in the XKR (top grain with a light coating over it), and the taurus in the XE. I thought that the taurus was pretty good, for a corrected grain. I've seen plenty worse, that's for sure.
Not a lecture, just pretty fascinating stuff. I hope I got it all right, it has been a few years since he told me.
Are you sure there is no benefit to conditioning corrected leather? I noticed that unlike my SL, conditioner isn't readily absorbed into these seats. Maybe that is why. My concern is that stitching that runs right at the edge on the seat cushion will crack up with time unless I find a way to re-hydrate the leather. It is rather hard right now. It will be especially noticeable on my white seats, as any cracks will be instantly visible.
Try a little Lanolin-based product on the leather. If it soaks in, you're good to go. If it just sits on the surface, wipe it off and move on.
That said, both the smooth leather on the wheel, and the full grain leather on the seats positively slurped the lanolin on my base V6. It felt dry to the touch before, so...
Hi. I usually work on the basis that it cant hurt to put the decent stuff on leather even if it isnt top grain. I use a lanolin based product for the obviously corrected grain seats (RM Williams boot conditioner). But I save the really expensive cleaner and conditioner (the ones for analines and semi analines) for stuff I know is top grain.
The car I get (today - woohoo!) has "premium leather" which I am assuming is a top grain, probably with a poly coating.
Leather does naturally get softer with use, and the seats get much more comfy over time. The driver's seat in my XKR (with about 40000 miles on it) is super comfortable because it has been stretched and absorbs the bumps. The passenger seat is still like new, so you feel the bumps a lot more.
SinF (04-12-2016)
you really don't need to use a conditioner anymore as all new cars have a pu coating on the leather for wear/protection
you can see this by just spraying water on the leather and seeing it bead, rather than soak in
conditioner does the same thing, it'll never penetrate the coating. it'll feel a little softer initially but it'll end up transferring to your clothes and just wearing away quickly
leatherique prestine clean or angelwax heaven for leather are great products to use
Up until about 10 years ago, I treated all the leather in my cars with expensive, high-quality products. At some point, I noticed it wasn't doing any good, and just quit. It really doesn't make any difference in how well the leather wears in modern cars given the coatings applied to today's auto leathers.
Smoke Em (04-12-2016)
I suspect you'll get used to them as most who have them report them as comfortable enough.
BruceTheQuail (04-13-2016)
The following 2 users liked this post by Unhingd:
BruceTheQuail (04-13-2016),
Smoke Em (04-13-2016)
