Sport vs reg Drive mode...
I've been recently driving more & more in the Sport "S" mode lately vs just the boring regular Drive "D" mode in my R convert.
Probably up to 30% of the time, that's when traffic clears up a little bit on the roads.
Just curious, how often do you guys drive in S vs D mode?
Also, for auto transmission, How much/often ya'll shift manually? Maybe only 5% of the time for me...
Nightshadow (03-10-2020)
I'm a little confused here.
I drive in Dynamic mode 99.9% of the time, the other .1% in Normal mode only when it's absolutely pissing down (it never snows and there is never any "black ice" where I drive).
I use S mode about 20% of the time, when traffic allows.
But people here are talking about "how often do you manually change gears in S mode", when my understanding and all my experience tells me that when you are in S mode you HAVE to manually change up, you simply have no choice, the car will hit redline and bounce off the rev limiter all day and still not change up!
It changes down automatically as you come to a stop yes, but never up!
Or, as I suspect, does S mode work differently (ie auto change up) if you are in Normal and not in Dynamic?
I don't think I have ever driven the car in that combo, might have to try it and check it out one day.
D (Normal Mode) in Stop and go traffic
S Mode the rest of the time, stays in automatic shift mode until you start using the paddle shifters.
Paddle shifters in the twisty bits or when the mood hits me.
With paddle shifting it will stay in gear and redline.
Holding the Up shifter for 3-5 seconds will switch back to automatic shifting while in S Mode.
Note: When the transmission is set to
permanent manual mode and Dynamic mode
is selected, transmission upshifts are fully
controlled by the driver. The transmission will
not change up automatically, even when the rev
limit is reached (the gear position indicator in
the Message centre will glow amber, to indicate
that the next gear should be selected).
So this is how it works only in both Sport and Dynamic, and as I said I have never driven in Sport and Normal.
The following 2 users liked this post by OzXFR:
jaguny (03-13-2019),
OK, found it on page 82 of the Owner's Handbook, and it is exactly as I suspected:
I notice that when I first move the shifter over to S it doesn't show what gear it is in, but as soon as I shift up or down with either the shifter or a paddle it shows the gear.
I'll have to try it one day - D plus S but don't touch the paddles or the shifter, and see if it upshifts automatically.
But that seems completely pointless to me, why would anyone have it in Dynamic & S and NOT then use either or both of the paddles and the shifter?
Hmmm.
It shows the gear when you use the paddles to indicate it's in manual mode. In D it'll shift automatically unless you touch the paddles to switch to manual and will revert to auto if you leave the paddles untouched for a few seconds after using them. In S it will stay in manual once the paddles have been touched. It won't upshift automatically in manual mode. I don't think dymanic mode alters the behaviour of either D or S.
Other than that, I think there has been a little confusion between D = Drive and D = Dynamic in this thread (not by you I might add).
"Dymanic" mode (I like it, I call Dynamic "Dimaniac"!) most definitely alters the behaviour in Drive, it holds onto the gears longer before changing up and changes down with a little more urgency, and the throttle response is a little sharper.
