sprintbooster
Kidding aside... look at the price of this BS
https://www.bonanza.com/listings/3-e...AaAvH4EALw_wcB
How about a group buy of this tuning chip... Stage 22 and 155Hp. I need that!
https://www.ebay.com/itm/Stage-22-15...Ba7YaN&vxp=mtr
I'm afraid you've misunderstood the term "horsepower," that is: work done, meaning mass moved, over time. You can't measure "horsepower at the crank" without first assuming that rpm is proportional to distance. That's a necessary assumption to make engine comparisons easy for people who don't get the physics.
I know it's like science and stuff but if you want to argue an opinion, it's important to understand what the terms actually mean and the assumptions behind each concept. Otherwise, you are right, it isn't worth arguing.
To the OP, you are right that reducing throttle lag does provide power gains because power is defined by all as work done over time. So you can increase power by either increasing the work, or, by decreasing the time the work is done. Reducing throttle lag does the latter.
Lag is not a defined scientific term, like power, but it is an industry term to describe the time it takes to achieve a given throttle setting after the initiation of pedal movement. An on/off switch with no dampening logic would have no throttle lag.
Lag is not a defined scientific term, like power, but isn't it common sense that the time to achieve a given throttle setting after the first initiation of pedal movement is “laggy“ when it takes more time?
WOW, I have never seen anyone manipulate the somewhat correct concept of HORSEPOWER in such a manner. Anyway the POWER is the result of Torque X Angular speed. It tells you HOW MUCH WORK an engine can do at that given speed with that TORQUE. That is if we want to simplify that. NOWHERE it matters the rate of speed change. So, please I ask that you stop spreading BS.
The full stupidness of pretending "shaft horsepower" (the correct way to characterize manufacturer supplied BHP) is a meaningful proxy for speed or acceleration is that a Mac Truck has more shaft horsepower than a Yugo. But the Yugo is going to win every race.
To the OP, if a sprintbooster reduces throttle response time, it does add power. Not torque (the accelerative Force in F=MA), but power (distance the Mass of the car moves over some amount of Time).
As I calculated above, a very small decrease in throttle response time can equate to a rather large power increase especially when tests take little time. A 0.1 sec decrease over a 3 second test equals exactly 25 HP at a vehicle weight of 3500 pounds.
Yep. It is. Technology too, but either way, I think I 'm on the science/technology side of things. Some software too. I'm also on that side.
#28
Do we have a facepalm emoji here? Can the mods install it if not?
Has the dead horse named SGREENLYN been reincarnated?
Are we going to get into time travel like last time?
The pedal has no lag and no dampening effect.
Source: actual testing with data logger.
I really can not believe we're having to do this yet again.
Isn't fake science great?
#30
https://www.ebay.co.uk/itm/Sprint-Bo...oAAOSw4a1bVoME
a friend of mine put that on a v6
wow amazing...so the question is can this damage something... i had that on porsche cayman and no problems at all only 1 time the switch go broke but the sprint booster no
so i want buy it for reduce the lag throttle but a little bit scared
on maserati forum i read horror stories
#32
#33
How many times need someone here say "there is no throttle lag" before it reaches through?
The only "lag" (which is not a lag by definition) is the time it takes for a person to physically press the throttle from zero throttle to full throttle - which for a normal person would take less than 0.1 sec, if you want to.
If you increase the sensitivity of the throttle pedal (= less movement of the throttle pedal is needed to reach full throttle), you might reach full throttle some 0.0x seconds faster, which might make it feel more responsive (= faster), but it is not.
Best case is that you end up with a car that feels a bit more responsive/stronger, without actually being so.
Worst case is you end up with a car that is not faster, but too sensitive on the throttle to be able to modulate it when take off or out of corners. Which in all practical ways will make it slower.....
#34
Please explain how a vap tune makes your car slower? The same thing can't be slower in one application and faster in another.
Third, the only way a car can feel faster is to be faster. Feel comes from acceleration: F=MA. Same force (torque), same mass (car), so feel can only come from only place, more A.
More A can only come from less time elapsed, since we all agree torque is unaffected by laggy vs. snappy throttle curve.
#35
I think most have already agreed there is throttle lag. The first response suggested a vap tune to make throttle response much more aggressive.
Your an idiot or just gullible, please go away with your BS spreading, were not fools here that believe your snake oil. Most of us here have tuned cars our self, or written throttle maps.
Pedal devices adjust throttle sensitivity and that is all they do, zero impact on performance and horsepower.
Your the one trying to use fancy formulations to prove something that in fact does not exist and not relevant to a pedal booster.
You need to get back on your spaceship and go back to button moon, you might have more luck there.
Also funny how you say we have all agreed with you, not one single person in this thread has agreed with anything you have posted, infact were all telling you the same, stop spreading total BS and lies, only you agrees with you, no one else here.
Your failing at trying to convince us and you will not succeed, but I guess you have a lot of time on your hands.
The only way you get more horsepower and actually improve performance is with hardware changes or ECU remapping, or a combination. A device that changes the throttle sensitivity has no impact on performance whatsoever, so give up!
FType17 (07-26-2018)
#36
VAP tunes makes the car faster because it is a tune that actually increases power (hp and torque). It also changes the throttle sensitivity to a certain degree, but that is not what makes the car faster/stronger.
Change in throttle sensitivity might make the car feel faster without being faster. It's just because the driver needs less throttle input to reach full power, and therefor the car feels faster - but it has just become more sensitive to throttle input. A passenger would not notice any difference if the driver floors it (either way).
The reason a too sensitive throttle might make the car slower in real world use, is very simpel. Just take it to the extreme and replace your throttle with an on/off switch were on is full throttle input and off is no throttle input. All "lag" (which is not truly lag but just how much/fast you need to move the pedal before you reach full throttle) is gone, but also all neccessary throttle modlulation and sensitivity is gone. The car will be slower at take off (due to traction problems) and slower for all other driving purposes (and it still has exactly the same power).
You seem to lack the understanding of "drivability"? A too powerfull car can be slower than a less powerfull car, if the "driveability" is poor. A too sensitive throttle can make a powerfull car slower in real world usage.....
It's rather easy to understand if you live in the real world.
And please stop lying will you.
#37
Sorry, I didn't understand your point. The work in "HP" is literally the car's mass moving some distance. The power in HP then divides that work by time required to do it. Obviously dynos can only assume that rpm is proportional to moving the mass of the car, but we all know that is wrong. HP measured at the wheels is a better number, but it still falls short of measuring the real work done, which requires actually moving the mass of the car. That's why adding an electric motor or three increases a car's HP. It's not about any one component in isolation. It's about movement of mass over time.
#38
Please STOP attempting to manipulate terms and formulas. Force is NOT Horsepower. Please quit showing your ignorance and attempting to make some idiotic point. Granted, an argument can be made for the ability to deliver higher torque and therefore power sooner, the HP, and Torque does NOT change. If in your twisted way, you are attempting to say that a given car coming in at 2000lbs and having 500hp can reach the same speed as a car coming in at 1500lbs and 400hp as well as a 3000lbs car with 700hp in the same time.... you are correct. However, the above are just random weights and HP to illustrate a point, a proper power/weight ratio comparison would be more accurate. Even in that case, the acceleration rate would be the same....
Confusing physics noobs even more, Dynos are rather poor approximations of power, since rpm is treated as a proxy for distance, which is a bit or majorly wrong in all cases. That's why amateurs think cars like the Nissan GT-R "defy physics " because they have zero understanding of physics. A GT-R dyno test, where RPM is used a fake distance traveled per time, reveals how terribly inaccurate Dynos are when it comes to blind guessing a car's true power.
The only accurate way to measure total power, all motors, systems to lay down power, and lag reducers included, is to actually time the mass moved some distance in some amount of time. There's no opinion allowed, that's the physical definition of "Power" explained for laypeople.
#40
I guess the question is what's left. Since VAP implents such a big throttle aggressiveness change (reported by reply 1) it seems the answer is, a lot is left. My V8 seems laggy even in Dynamic.
