Squeaking from rear when going slowly
I've recently purchased a V6S Convertible which I'm completely loving but when driving slowly around town a quite loud squeak emits from the rear when slowing down (both when braking and when the engine autocratically gears down).
When driving over 20-30mph no squeaking occurs whatsoever.
Has anybody experienced this issue? Going to take it to the dealers but it ruins a day for me so would like to go knowing whats wrong.
Thanks in advanced,
Cheers,
Sam
Thanks in advanced,
Cheers,
Sam
Thanks in advanced,
Cheers,
Sam
Thanks in advanced,
Cheers,
Sam
thanks w
JTB00306v5
I was just out for a drive in my V6S and started hearing an intermittent squeal from the rear of the car. It sounded just like an old fashioned mechanical brake pad wear sensor kicking in and out.
I thought F-Types had an electrical sensor for this rather than the mechanical type that squeals.
Anyway my car has only 19k on it. Could I need new rear pads already? Usually the fronts go first unless something is wrong with the rear brakes.
BTW: If there is an electrical pad wear sensor how does the car warn you about needing brake pads?
Received 3,226 Likes
The F-Type has the same ancient pad wear sensor system as the XF.
A single sensor on the right rear inner pad and another single sensor on the left front inner pad.
They are simple "open loop" wires, so that when the sensor wears through the loop closes and the warning is triggered.
On the XF they are meant to trigger when there is around 4 mm of pad thickness remaining, so plenty to spare. But that is only the triggered pad, it's possible that other unmonitored pad(s) could have a lot less, and the OEM pads are notorious for falling to bits around the edges once they get low.
If it's anything like the XF then you will get a warning on the dash "brake pads low" or similar, but it doesn't tell you which sensor has triggered, so you need to manually check.
One or more brake pads worn out at 19k miles, especially the rears, would not be unusual, the OEM pads are very soft (hence the masses of dust) and they wear out very quickly.
On the XF the rears wear much faster than the fronts, due mainly to "anti-dive" built into the braking system such that the rear brakes grab faster and harder than the fronts. I don't know for sure but I suspect the F-Type would have the same system.
So your best bet is to whip all the wheels off and have a good look at the thickness and condition of all the brake pads, well at least "edge on" without the hassle of removing the pads.
RGPV6S (05-22-2017)
My issue actually turned out to be a problem with the exhust system, can't remember the detail exactly but it was something to do with the values (that make it sound ace) not sealing correctly which is why it only happened at lowish revs. In the end I believe they replaced the whole rear exhust system under warrenty.
Hope this helps,
Sam
Hi
Hope this helps,
Sam
Hope this helps,
Sam
Hope its not the exhaust valves like Sam.
Hi
Hope this helps,
Sam
Hope this helps,
Sam
This will be the subject of my next dealer visit, as I've consistently noticed these exact symptoms. Particularly noticeable in parkades.
Right now I'm playing a game.
It's called "common issues bingo".
I seem to be doing fairly well at this game currently.
If I win the game (while still under warranty), then I get to do mods! 😁
The electric vacuum pump for active exhaust sounds very much like a buzzing heat shield - it's located behind/inside the left rear wheel. It's most noticeable for me around 1400RPM. Don't know what year you have; the pump was removed in MY16 (17?) and replaced with a vacuum line coming back from the engine.
Luc Lapierre (05-16-2019)
I have VIN ending in 27692 by the way.
Ah, the anecdotal evidence is growing - I did a cold start yesterday and crawled around to see if I could pinpoint the source, this is the exact location I determined. Took a video too in case it decides to behave itself at the dealer.
https://youtu.be/nSDFepGjAQU
