Squeaky Seats
Greetings all,
Does anyone have squeaky seats? I’m 6’1” so I move my seats all the way back and I believe the seats are rubbing against the rear bulkhead. Anyone had this problem and know of a more elegant solution than stuffing a towel behind the seat or something? Thanks as always.
I make sure mine aren't just against the rear bulkhead but *really* against it by setting the recline first and then motoring the seat base back until the seat back is pressed firmly against the bulkhead. If that's not how you want to do it, a bit of self-adhesive felt from the craft store applied to the contact point will stop the squeak.
Be advised that craft store adhesives don't tolerate the heat of auto interiors very well. ![Icon Bricks](https://www.jaguarforums.com/forum/images/smilies/icon_bricks.gif)
I'd suggest using Armor-All or a silicone spray to see if that will stop the squeaks. Apply sparingly to one area at a time so that you can determine what is rubbing. Bear in mind that these products will prevent good adhesion later, if you decide to try the felt at a later date.
I'm not your height, but I still had the squeaks. I found these seat belt shoulder cushions worked.
https://www.target.com/p/turtle-wax-...ce=1&gclsrc=ds
Then for other squeaks and rattles, I bought this... black and 1/4 in thick.
This might work to hang/mount it. Adhesive on one side... cut a piece for the car interior and matching for the foam.
Atipical (05-13-2024)
https://www.amazon.com/Randall-Repla...92&sr=8-7&th=1
https://www.amazon.com/Dual-Reclosab...5607160&sr=8-4
