Squealing from rear at low speeds
Hey guys - long time lurker, first time poster (do people still say that?), but I need some help!
Today as I was driving through a parking lot in my '15 F-Type, I took a left turn (super low speed) and felt a slight grinding/vibration from the back end - I assumed it was a pothole that one of my tires was briefly stuck in, and continued my drive as normal with no other issues/sounds. Unsure if these two issues are related, but fast forward about 30 minutes as I'm pulling into my driveway, and I notice a pretty significant squealing coming from the back end. The noise was happening under 25 MPH, and while I was in park. It almost sounded like a constant whistling sound?
I've scoured the forums and it looks like a handful of people have had a similar issue with exhaust valves - but due to the fact that I felt that grinding/vibration in a turn earlier in the day, I don't know if that's my issue. Anyone else ever experience anything similar? It's certified, so I'm assuming/hoping whatever it is, it's covered under warranty, BUT I have a 45 mile drive to the nearest dealership, and I don't want to have to make that twice...
Thanks in advance!!
Thanks in advance!!
Thanks in advance!!
Thanks in advance!!
Received 3,209 Likes
I occasionally hear some chatter from the inside rear wheel when I both turn sharply and accelerate in my 2014 V8, sometimes with slightly more z-axs rotation then I would expect from the steering wheel angle alone. I wondered if it could be a screwed up e-diff, too. But the car generally drives fine and accelerates evenly when pointed straight. After a while I decided it is the e-diff working, instead of not working. It seems to be a typical modern day, over-complicated solution trying to do too much and not working as well as the old fashioned, analog way.
