Squirrely back end (V8)
Gents, I have a F-Type S (V8) and often I step on the gas from a standstill or at a low speed the back end slips just a little bit before stabilizing and allowing the car to move forward. My tires are regular street tires (not anything exceptionally sticky). Traction control is default on. Dry and wet roads. Whenever this happens I back off the gas out of fear of losing control, or worse.
Presumably Jag could program the cars NOT to do this.. ie, when you hit the gas the car throttles the throttle allowing for a smooth yet powerful acceleration. Yet it happens to me quite frequently. So my question is: does the ECU allow a little fishtail for fun, and is this safe? Do you guys just "go with it" and assume the car will straighten out?
I previously owned a few 911s including a turbo and given the rear engine design the cars would never slip/slide/fishtail... just go. I know Jag tries to make the backend of the F-type heavier by putting the battery there, etc..
The following 2 users liked this post by addict:
Burt Gummer (03-06-2019),
SinF (03-05-2019)
^^^ i was thinking this exact same thing! The P-Zero's do lack in traction sometimes, but its a 500hp RWD....Try the PS4's (they are a better tire) but you can still wax those from a stop also with too much skinny pedal.
I suspect that Jag was assuming that you had at least some nominal control over your right foot. Not even my 450hp V6 will behave itself under a planted foot launch despite the MP4S tires and all the normal nannies deployed.
Control sure.. I can soft accelerate but it would be nice to have the car do a 100% efficient launch rather than me guessing where it should be. After all its an automatic tranny! I suppose this is why the V8 doesn't have a launch control like the V6 which basically goes full gas. Maybe there should be? I'll try the snow/ice mode as described above for my launches (shedding a tear).
The following 2 users liked this post by SinF:
red92 (04-05-2019)
The car has no way of knowing you will fishtail until you fishtail.
Same as anti-lock brakes.
The reason you are losing grip initially is without doubt the compound in your tries drying out, i.e they are getting old.
my 510hp V8R does not do this, until the tires get old.
Jaguar engineered three "fixes" to your problem.
- Cripple the V8S by putting it in snow mode.
- Get a 4-banger F-Type.
- Get an AWD F-Type (not really fair to compare with the 911 Turbo, otherwise)
The suggestion for Michelins is good advice, but won't solve the basic dynamics of putting that much HP in a RWD car.
Or, you could get a Hellcat and you'd forget your question.
