Start/Stop is here to stay
Article in the NY Times...
http://www.nytimes.com/2016/04/08/au...it-or-not.html
I use dynamic most of the time, so start/stop is off. But my other car is a hybrid, so I'm used to the engine starting/stopping in that. Though it's less obvious than in the Jag.
SinF (04-08-2016)
Initially, I was adamantly opposed start-stop feature. Now, I just grew to simply dislike it. Fortunately, with a MT I can control it to a large extent - if I keep the car in gear and clutch in, it won't shut off.
My objections to start-stop feature as follows:
1. It will shut off engine before its fully warmed up
2. It is not seamless, when it restarts I can often feel idle more prominently
3. It isn't intelligent enough to determine when you are pausing in traffic, and when you are stopped at the light and not likely to resume moving. Despite the car having back and front sensors that could be used to know if you wills tart moving shortly.
I drove hybrid loaner in the past, when you can go electric-only mode start-stop feature makes sense. Not in other circumstances.
I get more like mid 20s, but that's probably expected with the 8-speed. And those of us who have checked have determined the trip computer is about 2mpg high.
I was interested that the article mentioned 9- and 10-speed transmissions. I would think at some point a CVT makes more sense. Have one in my hybrid, and think it's great in that application. Can't see one in an F-type, however - wouldn't be right.
But you're right. Who cares? I didn't buy this car to worry about being able to afford to fuel it.
SinF (04-08-2016)
At some point, when electric cars reach a higher percentage on the streets, people will wake up to the fact that they aren't really "clean" at all, since the vast majority of them are currently powered by coal-fired power plants. The primary fuel source for the U.S. power grid will have to be completely revamped to make them actually clean.
SinF (04-08-2016)
Buckingham (05-23-2017)
+1. This is the first car I've had with ECO. Given the controllability offered with the MT (just depressing the clutch, lightening pressure on brake, putting light radial pressure on the steering wheel), the ECO feature is not intrusive to me at all and I enjoy saving shekels when I can.
I personally don't have a problem with it. The only thing that I wish was different would be allowing the car to be fully warmed up before the ECO mode kicks in. Other than that it works flawlessly.
Compared to my Audi Q5, the F-type has a faster restart and far more responsive. With the Audi it seems like it is always delayed for a second. With the F-Type as soon as you depress the clutch it starts up right away.
I've often wondered if a small turbine driving a generator, mated to electric drive, wouldn't make for a decent automotive platform. Not to be confused with the old turbine cars.
![](https://www.allpar.com/model/concepts/i/63turbinb.jpg)
Are you referring to an M1 Abrams tank? That has a nice turbine. And no, I've not been near one when it fires up.
CVTs are horrible. They take all the fun out of the car, they don't hold up and when one of the "rubber bands" inside one breaks they have to replace the entire transmission. Now I'm biased because it was exactly what happened to my sons Maxima. Nissan even had to extend the warranty on the transmissions to 125,000 miles because of all the failures. No I suppose there might be better CVTs out there but I don't ever want another one.
There are two wires attached to the right side (passenger) of the battery on the XF and the smaller one controlled the stop start. That is on the 2016 XF anyway.
Received 3,208 Likes
Yep, the very first thing I did on my F-Type when I got it home was to permanently disable the stop/start system by disconnecting the positive lead to the secondary battery.
Yes, I know I could simply hit the "Eco" button every time I started it up, but therein lies the clue - every time, what a PITA!
One thing that concerns me about auto stop/start is the long term effect on engine wear. I was always taught that the vast majority of engine wear takes place at startup - obviously as there's no oil pressure.
A while back, I actually counted the number of auto stop/starts the car made on a route I regularly take. It was 17. So that's 17 non-pressurized starts on a journey that would normally have just one. If you extend this out over a number of years and tens of thousands of miles, the number is huge.
I don't know all the technical justifications for the ability to have auto stop/start these days, but I guess that latest spec oils have the ability to cling to parts better, and engine tolerances are tighter than they used to be. Maybe this helps negate the wear effects of non-pressurized engine starts. Maybe the engine has a function to help hold oil pressure in an auto stop/start situation.
It's very nice to have improved fuel economy, but at what longer-term price? JLR will love the immediate benefits to them in marketing and corporate wide average fuel efficiency - what do they really care about the longer term reliability effect for customers?
I keep mine turned off, and its now a "muscle memory" type thing as part of my start procedure. Apart from the technical justifications I tussle with, every time the engine stopped unexpectedly (to me), it freaked me out. I've had too many cars over the years where a surprise cut-out was only a bad thing. Of course many of them had Lucas electrics!
